Thread: Stripped stud with lug still attached
Results 1 to 10 of 10
  1. #1 Stripped stud with lug still attached
    Jan 2009
    Tallahassee, FL
    I found a broken stud this morning and already got all new studs BUT I have another stud that is stripped and the lug won't come off. The lug backed out to a point fine but now won't come off and you can't tighten it back down. I'm at a loss here, how can I get this thing off without ****ing up the rim? All the other lugs came off fine to. Tried pulling/wiggling it off with vice grips since the thing is really but got nothing.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  2. #2 Re: Stripped stud with lug still attached
    Jul 2008
    sumter,south carolina
    put some heat to it
    02 GTP with mods 05 GP for DD
  3. #3 Re: Stripped stud with lug still attached
    Have access to NOS? Spray some on and knock it. =D
    That or a VERY large breaker bar. Perhaps a pneumatic impact drill.
  4. #4 Re: Stripped stud with lug still attached
    Charles City, IA
    Stripped as in just spinning on the stud right? If so hit it with a hammer to back the stud out a bit then cut the the back of the stud off and push it out the front. Heat will not fixed ****ed up threads. Neither will an impact.
    SMGPFC Two Nipple General
  5. #5 Re: Stripped stud with lug still attached
    You can't cut the back of the stud off if the wheel is still on the car.
  6. #6 Re: Stripped stud with lug still attached
    Charles City, IA
    Jack it up use a torch. I bet you I could.
  7. #7 Re: Stripped stud with lug still attached
    I fold.
  8. #8 Re: Stripped stud with lug still attached
    Jan 2009
    Tallahassee, FL
    Finally got it off with the help of my dad. With him basically pulling on the wheel and me backing the lug off it finally came off. Really there were no threads on the stud at all.
    77 Morris Garage B
  9. #9 Re: Stripped stud with lug still attached
    Aug 2012
    florida
    pry bar behind wheel
  10. #10 Re: Stripped stud with lug still attached
    3 year old thread hammer.
  1. How to remove TB spacer, attached with RTV
    By 04CompG in forum General Tech Discussion
    Last Post: 06-21-2009, 03:22 PM
  2. Stud removal
    By TheOtherNick in forum How To Write-Ups/Tech Tips
    Last Post: 01-04-2009, 11:21 PM
  3. How to fix broken wheel stud?
    By ryangtp89 in forum Brakes/Suspension/Chassis
    Last Post: 10-08-2008, 10:59 PM
  4. &#@$ing Wheel Stud
    By Abrasive in forum The Rant Forum
    Last Post: 04-01-2008, 05:44 PM
  5. rear wheel stud-how to get it out and new installed?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 03-03-2008, 03:47 PM
