Thread: Adding a 2nd MAF?
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 66
  1. #1 Adding a 2nd MAF?
    Omaha, NE
    So... Sometimes I get crazy ideas.
    What would it take to add a second MAF? I have been curious about twin charging a Grand Prix for the past 10 years and haven't tried it yet. I want to avoid hitting the wall at the blower, so I was thinking about having a custom lower intake manifold made with a port for the cold side of the turbo setup.
    Something like this:
  2. #2 Re: Adding a 2nd MAF?
    Antioch, IL
    How are you going to stop the sc from compressing the turbo since the sc is instant boost?
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: Adding a 2nd MAF?
    Kemmerer, Wyoming
    I would be curious how the pcm would control the fuel with 2 mafs
  4. #4 Re: Adding a 2nd MAF?
    I don't know of any software that would allow that and have anyway to control it.
    Ideally it would be so much easier to just ditch the factory computer, run a MS3 system or similar and just delete the MAF altogether. Run a true speed density setup with a 2-3 bar MAP sensor and be way ahead of the game.
  5. #5 Re: Adding a 2nd MAF?
    Omaha, NE
    The SC would basically force the turbo's air into the motor more efficiently building more boost. The restriction in twin charging the traditional way is by the compressed turbo air hitting the supercharger rotors. With the turbo'd air going under the blower, it's bypassing the rotors.
    Sent from my iPhone using Tapatalk Pro
  6. #6 Re: Adding a 2nd MAF?
    Omaha, NE
    That's not a bad option.
  7. #7 Re: Adding a 2nd MAF?
    Antioch, IL
    If the SC is on top of the engine and the turbo is blowing into the lim that the sc is compressing, which will compress the turbo because it starts compressing itself since the sc is compressing compressing ( ) how are you going to stop the sc from blowing the psi out the turbo before it builds boost? And said turbo builds more psi than sc, how would that boost not go backwards and out the sc throttle body?
  8. #8 Re: Adding a 2nd MAF?
    Omaha, NE
    Quote Originally Posted by ItHurtz View Post
    Blow off valve, and boost bypass valve hopefully. During acceleration, I would think the air would be moving too fast to push backwards.
  9. #9 Re: Adding a 2nd MAF?
    Antioch, IL
    You havent thought this through, it wont work.
  10. #10 Re: Adding a 2nd MAF?
    Aug 2016
    MN
    This. Sometimes crazy doesn't mean good lol.
    I can't imagine it working, if it did someone would have done it by now.
    1998 Grand Prix GTP aka The Family Sedan
    CAI, 1.8 rockers, U-bend delete, 3.4 pulley, tuned by me
    1999 Turbo Grand Prix
    L36 turbo build in progress
  11. #11 Re: Adding a 2nd MAF?
    Omaha, NE
    Why not?
  12. #12 Re: Adding a 2nd MAF?
    Antioch, IL
    Because 2 inlets with varying psi, one is going to become a outlet, the turbo nor sc are anti reverse and 100% one way sealed.
  13. #13 Re: Adding a 2nd MAF?
    Omaha, NE
    The engine is the outlet. If anything I blow the heads off the block.
    Think of it this way. You've got a garden hose with a hole in the middle. You and someone else are blowing from each end of the hose. Where's the air going? It's going to back up (creating more boost), but it's going out the hole.
    I could be wrong. I'm not an engineer.
  14. #14 Re: Adding a 2nd MAF?
    Antioch, IL
    What if your a smoker and your friend has big lungs, your going to eat your friends breath
  15. #15 Re: Adding a 2nd MAF?
    Aug 2016
    MN
    It will go out the path of least resistance, the manifold pressure is created because the engine already can't draw it in fast enough
  16. #16 Re: Adding a 2nd MAF?
    Omaha, NE
    Boost vs Boost vs Motor.
    Some head porting may be necessary to make this work. Bigger intake and exhaust ports and valves would help reduce resistance.
  17. #17 Re: Adding a 2nd MAF?
    Antioch, IL
    Your a idiot, move on it WONT work.
  18. #18 Re: Adding a 2nd MAF?
    Omaha, NE
    *You're
    *WON'T
    Would you like to place a wager kind sir?
  19. #19 Re: Adding a 2nd MAF?
    Aug 2016
    MN
    I wanna watch...from a safe distance.
  20. #20 Re: Adding a 2nd MAF?
    Antioch, IL
    eye for a eye or life for a life? I personally like the life game.
    Now go build a plywood box and stick a dryvac blowing on top, then stick a leaf vac on the side and tell me what happens.
  1. Adding Hud
    By avengegt in forum General Tech Discussion
    Last Post: 11-10-2015, 11:08 AM
  2. Adding hud to a 06 gp gt
    By 2006GrandPrixGT in forum General Tech Discussion
    Last Post: 08-31-2015, 07:28 AM
  3. Adding TC to 97 GTP
    By Prixer97 in forum Brakes/Suspension/Chassis
    Last Post: 03-17-2014, 08:38 AM
  4. adding a hud
    By 1LoudGrandPrix in forum Visual/Body Modifications
    Last Post: 08-17-2009, 09:07 PM
  5. Adding HUD ??
    By aries83 in forum Visual/Body Modifications
    Last Post: 03-16-2009, 07:45 PM
