Thread: p0300 code w/ N* tb lq4 and tre 80lb injectors
Results 1 to 20 of 21
Threaded View
  1. #1 p0300 code w/ N* tb lq4 and tre 80lb injectors
    SE Level Member 40thAnnGTP2002's Avatar
    May 2015
    high point nc
    hello all fellow w-body people I am trying to fig out a p0300 random misfire code I have. First off, it is ONLY at idle and no other time. 2nd)I have the following mods; Gen v w/ a 2.8 and KYGTP Beltwrap(THANKS AGAIN STEVE!) and Northstar Throttle Body w/ LQ4 MAF on 16* timing with yella terra 1.95 roller rockers and crow 105# springs w/ zzp modded retainers and comp valve locks, also have Tre 80lb injectors and a Tre 255 fuel pump with a caspers hotwire kit. I am on E85 and also a milzy fsic fb 101 fmhe flowjet ic pump. I have factory Acdelco wires and AL 103 plugs gapped at .045. I don't have an EGR Valve bc I deleted it and I also deleted Evap solenoid. Car runs great other than the random misfire, I can feel it but have no clue whats causing it bc as soon as I give it gas-it goes away. 3rd) I have tried the following; diff plugs and wires, maf, map, idle air control valve, sprayed brake cleaner around intake and sc for leaks and I have 0. also tried all diff coilpacks, icm, and even reverted back to l67 throttle body. I have used tiny tuner and played w/ inj offset vs battery voltage and low pulse width inj offset vs pulse width vs map. ANY AND ALL HELP WOULD BE GREATLY APPRECIATED!!!
    The joy of getting pulled on an interstate...
    Cop: "License & Registration, Do you know how fast you were going?" Me:"I was just trying to keep up with the traffic." Cop Looks Around:"There is no traffic." Me: "I know, that's how far behind I am!!!"
  1. Relentless P0300 code
    By gofast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2016, 08:50 AM
  2. P0300 code , need help !!
    By damohr in forum General Tech Discussion
    Last Post: 03-04-2015, 07:44 PM
  3. someone help? p0300 code
    By ericg1181 in forum General Tech Discussion
    Last Post: 04-07-2014, 02:09 PM
  4. most common p0300 code fix
    By Wingsfreak9 in forum General Tech Discussion
    Last Post: 09-21-2011, 01:12 PM
  5. Sputtering and P0300 code
    By grngt97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 02:12 PM
