Thread: Adding Hud
Results 1 to 8 of 8
  1. #1 Adding Hud
    Nov 2015
    lexington sc
    I want to add a heads up display to my gt. the one I got from the junkyard came from an 04 and my car is 00. could I make it work or is it pointless.
  2. #2 Re: Adding Hud
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    I think you need a special windsheild not 100% sure though. I'd like to see what people say also I was wondering if it was possible to put in my 2000 gtp if its worth doing.
  3. #3 Re: Adding Hud
    Seeing how the 97-03 and 04-08 are completely different body styles, it's not going to be a easy swap or it likely will not work at all.
    You'll have to see if your car is even wired for HUD, see if they are in the dash.
  4. #4 Re: Adding Hud
    Oct 2015
    Harvest, AL
    You need one out of a 97-03. Car does not have to be prewired, you can splice all the connections. I just got done adding one to my 01. There is a great thread on here with wiring diagrams and other info.
    '01 GTX Clone- bagged, shaved, custom paint, more
    '09 CTS-V - Airaid, Borla, blacked out, 20" Niche Targas
    '95 C/K - 2/4 drop, 18/20 Ridler 645, custom paint
    '06 Corolla- beater. Someone buy it
  5. #5 Re: Adding Hud
    SE Level Member walkure's Avatar
    Aug 2011
    Puyallup, WA
    '99 was the last year that came pre-wired.
  6. #6 Re: Adding Hud
    Nov 2015
    lexington sc
    I didn't think so but I thought it would be cool since the hud display is different in the 04 through 08. Well since I can't do that I'll have to see if I cant my digital dic (this did come out of a 98-03 gt) finished I got gray wires coming out the stock harness and brownish grey on the dic and screen won't come on. I done check forums and threads and it's suppose to have gray wires on the dic so I have no clue
  7. #7 Re: Adding Hud
    Apr 2011
    Elk Rapids, Michigan
    2001 black GTP coupe, Gen V, ZZP S2IC & billet fuel rails, XP cam, LS7 lifters, 105# springs, ZZP MPS w/3.4 pulley, Northstar tb, LQ4 maf, ZZP headers, K & N CAI, Meziere electric wp, Caspers fp retire, F body front brakes, GMPP strut braces​, Don Rome strut brace mounts.
  8. #8 Re: Adding Hud
    SE Level Member keatonregal's Avatar
    Mar 2015
    Port Huron, MI
    No need for a special windshield, stock is fine, HUD windshield is too much anyway.
    1999 Buick Regal "Betty White"
    NIC Cam FSIC E85 Built Trans Flaky Paint
    Ported Aluminum Coolant Elbows
  1. Adding HUD and a DIC to your 97-03 GP
    By $03gp/gt$ in forum How To Write-Ups/Tech Tips
    Last Post: 10-12-2015, 07:25 PM
  2. Adding hud to a 06 gp gt
    By 2006GrandPrixGT in forum General Tech Discussion
    Last Post: 08-31-2015, 07:28 AM
  3. Adding TC to 97 GTP
    By Prixer97 in forum Brakes/Suspension/Chassis
    Last Post: 03-17-2014, 08:38 AM
  4. adding Nav to a GXP
    By sasquatch094 in forum General Tech Discussion
    Last Post: 03-15-2013, 06:22 PM
  5. Adding HUD ??
    By aries83 in forum Visual/Body Modifications
    Last Post: 03-16-2009, 07:45 PM
