You can sneak the valve cover past w/o needing to fully pull the alt bracket as Scott says.
Also.. big thing here.. were the grommets on the valve cover bolts replaced at the same time? If not.. your issue isn't the gasket, it's the grommet....which is all that puts pressure on the gasket to seal it.
