Thread: 99 GT won't run URGENT
Results 1 to 20 of 39
  1. #1 99 GT won't run URGENT
    SE Level Member 1FastGP's Avatar
    May 2015
    Indian Trail, NC
    99 GT ran just fine other day now won't crank unless you hold your foot on the gas, no codes
    Sent from my SM-G900V using Tapatalk
  2. #2 Re: 99 GT won't run URGENT
    crank means the engine turns over ... start means the engine fires up and starts and runs.
    I'll assume you mean won't start. Unplug the maf.. use the throttle to start it and after a couple of times, I bet it runs fine. So likely the maf is bad
  3. #3 Re: 99 GT won't run URGENT
    May 2015
    Indian Trail, NC
    Yeah sorry I probably should have worded that better spins over quite nicely but won't start and run unless you put ur foot in it already tried it with no maf and maybe unrelated but the "trac off" light won't shut off
  4. #4 Re: 99 GT won't run URGENT
    Open the radiator cap.. you getting low on coolant? if so.. the UIM is failing and soon it'll hydrolock if you don't take care of it.
    But..that's only if it's using coolant.
  5. #5 Re: 99 GT won't run URGENT
    GT Level Member mguzzo's Avatar
    Buffalo NY
    no start and trac light on can indicate bad Crank position sensor.
    without a signal from the CPS the fuel pump won't run. but if you say it starts with your foot on the gas then its probably not that.
    \do you hear the fuel pump prime?
    \do you have fuel at the rail after it primes?
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  6. #6 Re: 99 GT won't run URGENT
    trac light has nothing to do with starting.. nothing at all
    CPS is camshaft position sensor.. let's get it right and say CKPS for the crankshaft...but if a little throttle fires it up.. it's got spark.
  7. #7 Re: 99 GT won't run URGENT
    May 2015
    Indian Trail, NC
    Well it's full of coolant so pretty sure the intakes good but it does smoke a little white out the pipes once it's running this one's really beginning to stump me.
  8. #8 Re: 99 GT won't run URGENT
    Ok.. easiest thing to do.. pull the three 10 mm throttle body nuts off and slide it out of the way. If you see coolant pooled up right inside the intake, then you need to plug the coolant ports in How to Mod a Lim. that'll take care of the issue.
    If it's not soaked.. they you should clean the TB while it's off the intake. Likely it's horribly dirty. It's common.
  9. #9 Re: 99 GT won't run URGENT
    May 2015
    Indian Trail, NC
    Ok I'll have to probably do that tomorrow the car belongs to my grandma so it's at her house stuck in the garage.
  10. #10 Re: 99 GT won't run URGENT
    does it start and stall or just take throttle to start?
  11. #11 Re: 99 GT won't run URGENT
    May 2015
    Indian Trail, NC
    It takes throttle to start and stay running but soon as you take your foot off it dies again.
  12. #12 Re: 99 GT won't run URGENT
    clean the throttle body. i bet its all carbon-ed up bad.
  13. #13 Re: 99 GT won't run URGENT
    There might be more to it. A TB by itself shouldn't cause a stall.
  14. #14 Re: 99 GT won't run URGENT
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    idle air control ? bad battery ?
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  15. #15 Re: 99 GT won't run URGENT
    May 2015
    Indian Trail, NC
    I was thinking that, but it's going to the shop on Wednesday to check on that and not to mention we payed > $500 for them to redo the valve covers and intake gaskets 6 months ago and their still leaking all over the place so while I could change them myself it's just the principle of the thing that they should fix them for free.
  16. #16 Re: 99 GT won't run URGENT
    Dec 2014
    Maryland
    first i'd pop the maf , and iac out and clean them with maf cleaner and see what that does. and check the battery voltage.
  17. #17 Re: 99 GT won't run URGENT
    May 2015
    Indian Trail, NC
    Already did the maf, still need to do the IAC and I just put a brand new battery in it yesterday.
  18. #18 Re: 99 GT won't run URGENT
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by 1FastGP View Post
    Are you talking about just the VC gaskets leaking? How do you know intake gaskets are leaking again?
  19. #19 Re: 99 GT won't run URGENT
    May 2015
    Indian Trail, NC
    There's oil leaking out from under both valve covers as well as between the upper and lower intake and all those gaskets were replaced about 1,500 miles ago
  20. #20 Re: 99 GT won't run URGENT
    Apr 2015
    After learning the hard way from Bill, your intake gaskets aren't leaking. It's the VC gaskets leaking down on to the LIM gasket, making it appear as if they're leaking.
  1. URGENT What is this?!
    By PioneerGTP in forum General Tech Discussion
    Last Post: 10-09-2012, 04:49 PM
  2. Need Urgent Help
    By ahl395 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 03-18-2012, 11:50 PM
  3. urgent need help misfire
    By gtcoup in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2011, 06:32 PM
  4. Urgent help
    By milfadic in forum General Tech Discussion
    Last Post: 05-20-2010, 06:02 PM
  5. Urgent need of Help
    By Sunstone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2008, 01:22 PM
