tapshift trans is its own animal
the connector at the trans has more pins than a std non tapshift trans. the pcm is also special.
but i know you can make a tapshift trans work with a gtp non tapshift bin file...it will throw all sorts of tapshift control codes.
so you either have a modified cG bin or they have an NA(base model) or GTP (non tapshift) PCM controlling that trans/SC engine
