Thread: Gtp comp g frankenstien help
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: Gtp comp g frankenstien help
    SE Level Member James8026's Avatar
    Feb 2015
    Michigan
    Switch fuse boxes and all why not just scrap it instead of doing all that work
  2. #22 Re: Gtp comp g frankenstien help
    Feb 2015
    Michigan
    And is the trans entirely different or just the shifter and wires can they be switched over?
  3. #23 Re: Gtp comp g frankenstien help
    hangover park IL
    its actually less work to unplug the fuse block to body plug and move it with the engine/trans to the new vehicle.
    there are like 40 connectors on the engine and some require a bit of work to get to/etc.
    if it were me id unplug the 3 conn's at the fusebox and swap it with the motor/trans too.
    plus they figured they could get more $ out of a "compG"
    my 04 would be more of a GTP clone than a compG as i didnt want tapshift but i wanted the 3.29's over the 3.05 FDR diff
    ~James~ Psychotic Gearhead
  4. #24 Re: Gtp comp g frankenstien help
    Feb 2015
    Michigan
    This is why i like my 70 fastback mustang, straight forward basic mechanics lol thanks for the help where are alternative vin locations like in the trunk and whatnot
  5. #25 Re: Gtp comp g frankenstien help
    Oct 2011
    Toledo, OH
    GTP and Comp-G shifters are not compatible. Different ratios, different electronics, different PCMs
    You car could even be 3+ cars matched together?
    7"
  6. #26 Re: Gtp comp g frankenstien help
    hangover park IL
    tapshift trans is its own animal
    the connector at the trans has more pins than a std non tapshift trans. the pcm is also special.
    but i know you can make a tapshift trans work with a gtp non tapshift bin file...it will throw all sorts of tapshift control codes.
    so you either have a modified cG bin or they have an NA(base model) or GTP (non tapshift) PCM controlling that trans/SC engine
  7. #27 Re: Gtp comp g frankenstien help
    Feb 2015
    Michigan
    Acually i got it for $2500 :-D
  8. #28 Re: Gtp comp g frankenstien help
    Feb 2015
    Michigan
    Very possibly 3 doners this cars from detroit from a shady dude lol craigslist
  9. #29 Re: Gtp comp g frankenstien help
    Oct 2011
    Toledo, OH
    Quote Originally Posted by James8026 View Post
    If it runs, and no codes, and is able to be registered, then you made out no matter how many cars it took.
    7"
  10. #30 Re: Gtp comp g frankenstien help
    Feb 2015
    Michigan
    Yea for sure i got a deal im happy w it i think theres a pic on my pf now
    Sent from my DROID X2 using Tapatalk 2
  11. #31 Re: Gtp comp g frankenstien help
    Feb 2015
    Michigan
    Has to be a gtp pcm then cause i dont get shift codes and it runs the supercharger/ boost gauge
  12. #32 Re: Gtp comp g frankenstien help
    Feb 2015
    Michigan
    This ones mine lol the gtp is for the wife
    Gtp comp g frankenstien help Attached Images
  13. #33 Re: Gtp comp g frankenstien help
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    I'm going to guess that you don't have a CompG engine or trans in the car. I personally did that swap on my car, and it's a lot more complicated then the typical Detroit salvage hackjob. More then likely you have a GTP with stock 2.96 gears and a CompG badge slapped on the side.
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  1. 04 Comp G
    By 04noobprix in forum Members Rides
    Last Post: 05-15-2014, 05:44 AM
  2. my first 04 gtp comp g
    By car illiterate in forum Introductions/Noob Questions
    Last Post: 06-22-2011, 01:03 PM
  3. Comp G trans in a non Comp G
    By Explicit_Spade in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2011, 10:31 PM
  4. 04 GTP Comp G (WIP)
    By snodly in forum Members Rides
    Last Post: 04-02-2011, 01:09 PM
