Switch fuse boxes and all why not just scrap it instead of doing all that work
tapshift trans is its own animal
the connector at the trans has more pins than a std non tapshift trans. the pcm is also special.
but i know you can make a tapshift trans work with a gtp non tapshift bin file...it will throw all sorts of tapshift control codes.
so you either have a modified cG bin or they have an NA(base model) or GTP (non tapshift) PCM controlling that trans/SC engine
