Thread: Gtp comp g frankenstien help
Results 1 to 20 of 33
  1. #1 Gtp comp g frankenstien help
    SE Level Member James8026's Avatar
    Feb 2015
    Michigan
    So i bought a 2005 gtp with the comp g package that has a salvage title. Its been wrecked and they used a 2004 grand prix se to put it back together (even the vin and dash) Now i called gm to get the options but soon figured out the title i had is for the 2004 so now im wondering how much needed replaced. Like for instance i have leather seats but no heat button on the climate control panel , does the car have a stock remote starter? Could it have have duel climate control? How can i tell? Honestly the car is clean and really well put back together so i could drive it how it is but if it has those options id like to be able to use them. Also its a comp g gtp shouldnt it have a hud?
  2. #2 Re: Gtp comp g frankenstien help
    It should have HUD, red calipers, sportier suspension, tap shift, different headrest, I don't think factory remote start was a option until 06+ but maybe im mistaken.
    04 Comp G.
  3. #3 Re: Gtp comp g frankenstien help
    Oct 2011
    Toledo, OH
    Why do you think it was a Comp-G? Does it even have a supercharger?
    7"
  4. #4 Re: Gtp comp g frankenstien help
    Feb 2015
    Michigan
    Yes it has a supercharger, leather seats, sunroof, and it has a comp g badge on the side of the car that wasnt replaced it has fuses for heated seat and coil springs but no tapshift or hud but dash and windsheild were replaced maybe even the steering wheel and counsal/shifter
  5. #5 Re: Gtp comp g frankenstien help
    Oct 2011
    Toledo, OH
    You should be able to get the heated seats back working by just getting the right Climate Control dash panel at least.
    DIC 5 button? What's your shifter look like? PRND321 would NOT be a Comp-G tranny. That is a lot of things missing it seems. Maybe a base model that got new engine and a few Comp-G panels?
    7"
  6. #6 Re: Gtp comp g frankenstien help
    Feb 2015
    Michigan
    Did ALL of the 2005 comp g have hud and tapshift or is that just an option? Can i install it aftermarket if not?
  7. #7 Re: Gtp comp g frankenstien help
    hangover park IL
    they would have had to yank out the dashboard and most of the interior to have swapped in the compG stuff.
    sounds like they swapped in the motor/trans and left it.
    you could find a comp G in the junkyard and yank it all out and swap into yours. probably take you a couple days
    ~James~ Psychotic Gearhead
  8. #8 Re: Gtp comp g frankenstien help
    Feb 2015
    Michigan
    Possibly i called gm according to them it a cloth interior base model but i cant see someone changing all the seats to leather and putting in different motor and all the books in the car are for the 2005 model plus the coil spring fuse now i was thinking what if they had to replace tge steering wheel Ã*nd the donor car was a se wouldnt they have to change the shifter assembly and counsel?
  9. #9 Re: Gtp comp g frankenstien help
    Feb 2015
    Michigan
    The comp g was the smashed car they put it back together with a 2004 se
  10. #10 Re: Gtp comp g frankenstien help
    Feb 2015
    Michigan
    Maybe a gtp with a fake badge?did regular gtps have normal transmissions?
  11. #11 Re: Gtp comp g frankenstien help
    Oct 2011
    Toledo, OH
    There wasn't an SE model until 2006...
    7"
  12. #12 Re: Gtp comp g frankenstien help
    Oct 2011
    Toledo, OH
    Normal GTP have the PRND321 shifter
    7"
  13. #13 Re: Gtp comp g frankenstien help
    Feb 2015
    Michigan
    Gotcha yea probly regular gtp did they have the suspension upgrade? That fuse still has me wondering
  14. #14 Re: Gtp comp g frankenstien help
    hangover park IL
    what you got was an 04 base model with a sc motor/trans and engine harness swap.
    possibly the 04 was in a small engine fire, and they had a compG to snag parts from.
    use a scan tool to grab the PCM vin
    if they didnt keep the tapshift trans then your pcm may be the 04's
  15. #15 Re: Gtp comp g frankenstien help
    Feb 2015
    Michigan
    And by se i ment base model i just assumed se
  16. #16 Re: Gtp comp g frankenstien help
    Swapping the seats aren't hard so I wouldn't be surprised if that was done.. It's suspension could of been swapped as well. Badges could of easily been added. It's hard to say what it really is at this point but it would have tap shift and hud standard.
    04 Comp G.
  17. #17 Re: Gtp comp g frankenstien help
    Quote Originally Posted by James8026 View Post
    SE = special edition and wouldn't have been until 06. Your better off saying a base model.
    04 Comp G.
  18. #18 Re: Gtp comp g frankenstien help
    Oct 2011
    Toledo, OH
    I assumed SE you were meaning "Standard Edition", but wanted to be on the same page. Like Turbo said, you probably have a base model with a Comp-G engine and panels, but not transmission. And if they had a Gomp-G donor... Might as well take the seats too.
    7"
  19. #19 Re: Gtp comp g frankenstien help
    Oct 2011
    Toledo, OH
    Also, where in MI are you? There is a lot of MI members, and a few NW OH ones too.
    7"
  20. #20 Re: Gtp comp g frankenstien help
    Feb 2015
    Michigan
    Nah the 2004 was the doner according to gm it was a reg 3800 with clothe seats and no sunroof my car has leather and a sunroof and a supercharger and 2005i information books i dont think someones gonna switch all the seats, cut a hole in the room, switch all wiring harnesses and not a trace of any of that on the car when i say clean i mean spotless i
  1. 04 Comp G
    By 04noobprix in forum Members Rides
    Last Post: 05-15-2014, 05:44 AM
  2. my first 04 gtp comp g
    By car illiterate in forum Introductions/Noob Questions
    Last Post: 06-22-2011, 01:03 PM
  3. Comp G trans in a non Comp G
    By Explicit_Spade in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2011, 10:31 PM
  4. 04 GTP Comp G (WIP)
    By snodly in forum Members Rides
    Last Post: 04-02-2011, 01:09 PM
