Thread: e85 swap questions
Results 1 to 20 of 67
  1. #1 Re: e85 swap questions
    Mar 2014
    Tucson
    Quote Originally Posted by 04lss View Post
    Thats my plan, maybe headers, and then work on my handling (swaybars etc) until i get my taxes back and go turbo .
    there's only one e85 station here close to my house, but the owner is running it in his car
    Handling?! What's that?
    I'm really looking forward to the octane gains. All I can get here is 91. Unless I want to pay $10/gallon for 110. Even with my listed mods, I'm still seeing 2°-3° of knock near 5k rpm on a stock pulley.
    Stupid CAN gas!
  2. #2 Re: e85 swap questions
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by BrandonHall10 View Post
    Stupid CAN gas!
    is it at shift?
  3. #3 Re: e85 swap questions
    Mar 2014
    Tucson
    is it at shift?
    I don't think so. I think it's all heat related. When I do a WOT run before the engine is fully warmed up, I see 0° throughout the RPM range. As soon as she gets hot, I see blips at the upper RPM range. Not much though. Before CAI and headers, I would see 4°+ degrees under at 2500 RPM during a hill climb (moderate load). IAT's were at or near 130°. It get's hot as balls here. I think if I had 93 vs 91 that couple degrees of knock would go away.
  4. #4 Re: e85 swap questions
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    I suppose I am tuned so my timing is adjusted to kill knock, but I had no knock on hot days on a 3.8 pulley gen 3 top swap, no headers or anything. (usually you have to run slightly larger pulleys on top swap because of the higher compression. ) I think i'm only running 14* of timing tho
    04 GTP -HAI, 1.9 rockers.
  5. #5 Re: e85 swap questions
    Mar 2014
    Tucson
    Quote Originally Posted by adecker View Post
    Go richer as temp gets higher... or there is a table that adjusts fueling based on WoT Time
    Quote Originally Posted by SnowTh1ef View Post
    I'm on a stock tune. A tuner is high on my want list.
  1. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  2. Top swap questions
    By killer84 in forum General Tech Discussion
    Last Post: 12-17-2010, 08:28 PM
  3. Some top swap questions
    By Traeger2591 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-23-2009, 07:45 PM
  4. Swap questions...
    By motohead in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-29-2009, 11:12 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
