Thread: Introduction/Fuel Pump
Results 1 to 6 of 6
  1. #1 Introduction/Fuel Pump
    Sep 2014
    michigan
    Hello everyone i am the proud new owner of a 2004 Pontiac Grand Prix GT2 with 190000 miles. I love the car and its loaded with every option including the head up display (doesn't work). I have an issue with my fuel pump whinning. I replaced the pump and it still whines am i missing something that will prevent the noise?
  2. #2 Re: Introduction/Fuel Pump
    they whine when the key is first turned its priming the engine for 5 seconds, after that you wont hear much from it.
  3. #3 Re: Introduction/Fuel Pump
    Sep 2014
    michigan
    I thought that also but it whines the whole time the car is running
  4. #4 Re: Introduction/Fuel Pump
    as long as it runs well id not worry so much.
    you can check the pressure at the rail on the engine.
  5. #5 Re: Introduction/Fuel Pump
    Sep 2014
    michigan
    I will keep that in mind.
  6. #6 Re: Introduction/Fuel Pump
    GTP Level Member buickman104's Avatar
    NYC
    My 2000 Gtp with 205k miles whines loudly the whole time. Don't have any issues with it other than it being loud. My brother in law's 2000 Bonneville ssei whines just like mine. His has 160k miles. Unless there is a noticeable issue I wouldn't worry about it. If it really bothers you then replace it.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  1. Replies: 7
    Last Post: 11-05-2014, 10:09 AM
  2. Replies: 5
    Last Post: 06-22-2014, 07:32 AM
  3. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  4. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
  5. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
