I live less than 4 miles and 8 minutes from the nearest e85 station. I'm going to have to do the conversion soon!
I was thinking of doing the 42.5 injectors so I didn't have to tune right away. Do the injector swap, and a pulley drop. Run that for a while to save up for my own tuner. I will probably hit you up for some tuning advice once I get there though.
I don't think so. I think it's all heat related. When I do a WOT run before the engine is fully warmed up, I see 0° throughout the RPM range. As soon as she gets hot, I see blips at the upper RPM range. Not much though. Before CAI and headers, I would see 4°+ degrees under at 2500 RPM during a hill climb (moderate load). IAT's were at or near 130°. It get's hot as balls here. I think if I had 93 vs 91 that couple degrees of knock would go away.
