Thread: Transmission problem? Help?
Results 1 to 19 of 19
  1. #1 Transmission problem? Help?
    Apr 2013
    Union City, In
    Started driving my car today had it sitting on jackets for a week had to work on the struts. Started driving it and it started shifting really hard whether i am going easy or hammering it. It shifts a lil softer when i am driving it hard? Makes no since to me usually its the oposit? anyone got any ideas or how to fix this? Thanks
  2. #2 Re: Transmission problem? Help?
    did you have the battery un hooked all week?
    if so that could be the tranny re learning how you drive. it should settle down with in a day or 2.
  3. #3 Re: Transmission problem? Help?
    Apr 2013
    Union City, In
    no battery never unlatched
  4. #4 Re: Transmission problem? Help?
    Dec 2012
    Where 4T65E's were born
    You should include the make/model/year/miles in a post like this.
    Sold.
  5. #5 Re: Transmission problem? Help?
    Apr 2013
    Union City, In
    99 grand prix gtp and 145k miles
  6. #6 Re: Transmission problem? Help?
    PA
    The transmission is probably going into limp mode for some reason. Possibly completely unrelated to have the car on jack stands unless you knocked something loose.
    The first thing to do is check your transmission fluid level and color. It should be completely full and the fluid should be a red color. Not pink, brown, black, etc.
    You could then try making the transmission relearn the adaptive shifts by unhooking the battery for an hour or so. Then drive it really easy for the first 50 miles to allow the transmission to adapt the line pressures.
    If all else fails, there is probably a trouble code stored in the PCM which will help pinpoint your issue.
    2001 GSE
  7. #7 Re: Transmission problem? Help?
    Apr 2013
    Union City, In
    it is a redish pink color. it is full of fluid.
  8. #8 Re: Transmission problem? Help?
    Dec 2012
    Is it making any usual noises like clunking or chattering?
    Sold.
  9. #9 Re: Transmission problem? Help?
    Apr 2013
    Union City, In
    no it sounds fine just slams into gear hard
  10. #10 Re: Transmission problem? Help?
    Quote Originally Posted by jman44 View Post
    you mean from park, or r to D? that would be your motor mounts being blown to crap.
    pop the hood and watch the engine as you shift it from P to R then to D, if its moving a lot, the mounts are shot.
  11. #11 Re: Transmission problem? Help?
    Dec 2012
    You may need to get it professionally looked at, with the appropriate scan tools to monitor shift patterns and the transmission pressure. It seems like your trans pressure is constantly at max.
    Sold.
  12. #12 Re: Transmission problem? Help?
    Sep 2014
    NY
    Is there any way to bypass limp mode? Is there a way to turn it off? I changed the fluid and unhooked the battery. Still in limp mode.
  13. #13 Re: Transmission problem? Help?
    Hi there new guy. Please post your symptoms, like how long it takes before slamming into gear etc. You might be able to use a shift kit to get around the issue w/o changing the solenoid. But we'll want a bit more info before making suggestions. Thanks
  14. #14 Re: Transmission problem? Help?
    Sep 2014
    NY
    It is as though there is no first gear or fourth gear. The car starts sluggishly in second gear and I think goes to third. Obviously an automatic, and I can force first gear. I feel like I am almost driving a stick shift. Still can't force higher gears. It is ok for driving around town, but too many RPMs on the highway. Thanks for the link to the kits. I'll check them out.
  15. #15 Re: Transmission problem? Help?
    May 2012
    Where winter never ends
    This.
    2000 Regal - Winter Beater
  16. #16 Re: Transmission problem? Help?
    Oct 2013
    Us
    It happened to me. Mechanic changed a valve in the transmission. It was an electronic valve as I recall. That fixed the problem for me.
  17. #17 Re: Transmission problem? Help?
    Sep 2014
    NY
    Electronic valve. Sounds like a good place to start. Thanks for the info Vbiagas.
  18. #18 Re: Transmission problem? Help?
    Dec 2012
    Those are called shift solenoids, and if that was easily diagnosed for vbiagas's car, there was likely a shift solenoid code, which made for an easy and direct diagnosis if you will. You could check for codes after the problem has occurred as many transmission codes reset with the key being removed.
    Sold.
  19. #19 Re: Transmission problem? Help?
    Oddly enough.. it sounds like you are only getting third gear. I'd check the fuses to the trans and then ohm the solenoids etc from there. You can test a lot with the trans in the car.
  1. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  2. Transmission Problem
    By rubent in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-14-2011, 10:34 AM
  3. transmission problem
    By jsucci in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2011, 04:59 PM
  4. Transmission problem
    By lhssnowman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-15-2009, 03:38 PM
  5. Transmission problem(s)
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-04-2009, 06:34 PM
