At 205k the cars running fine, hopefully it stays that way... Anyhow replacing the brakes and giving it a tune up this week. Here's the new, zzp oil filter, 180 thermostat, tr6ix iridium spark plugs, royal purple oil with a flush, antifreeze with a flush debating on the plugs should I go OEM or with the 10.3mm plugs from zzp. Also rebuilding the supercharger snout and purchasing a 2.5 zzp downpipe. I'm also planning on getting the k&n aircharger (kinda expensive) and then upgrading to the 3.4 pulley. Opinions? Advice? Feedback? Experiences? Open to it all.
