After several test fits on the S/C with the TB in place I found the perfect angle to mount the nozzle, elbow, and
check valve. I used thread sealer on all the connections, just to be on the safe side. It certainly doesn't hurt a
thing. It enters right below the TPS sensor, you'll see...
TB spacer and TB reinstalled with gasket matched OEM Gaskets with a little bit of Grey RTV to help sealing.
