Thread: Devilsown Stage 2 Progressive Alcohol Injection Install...
Results 1 to 20 of 37
Iron Indian Devilsown Stage 2 Progressive... 01-20-2009, 12:34 AM
Iron Indian Re: hkjljlkkln 01-20-2009, 12:36 AM
Iron Indian Re: hkjljlkkln 01-20-2009, 12:38 AM
Iron Indian Re: hkjljlkkln 01-20-2009, 12:41 AM
Iron Indian Re: hkjljlkkln 01-20-2009, 12:44 AM
TheOtherNick Re: Devilsown Stage 2... 01-20-2009, 01:28 AM
GeddyLee Re: Devilsown Stage 2... 01-20-2009, 02:27 AM
Guest Re: Devilsown Stage 2... 01-20-2009, 07:55 AM
Guest Re: Devilsown Stage 2... 01-20-2009, 07:57 AM
Bio248 Re: Devilsown Stage 2... 01-20-2009, 09:12 AM
fst Re: Devilsown Stage 2... 01-20-2009, 09:37 AM
Bio248 Re: Devilsown Stage 2... 01-20-2009, 10:44 AM
fst Re: Devilsown Stage 2... 01-20-2009, 10:48 AM
Reptile Re: Devilsown Stage 2... 01-20-2009, 11:04 AM
Iron Indian Re: Devilsown Stage 2... 01-22-2009, 12:38 AM
Iron Indian Re: Devilsown Stage 2... 01-22-2009, 12:41 AM
Iron Indian Re: Devilsown Stage 2... 01-22-2009, 01:19 AM
Guest Re: Devilsown Stage 2... 01-22-2009, 07:56 AM
Reptile Re: Devilsown Stage 2... 01-22-2009, 08:02 AM
Iron Indian Re: Devilsown Stage 2... 01-26-2009, 08:53 PM
Toofastgs Re: Devilsown Stage 2... 01-26-2009, 10:18 PM
Iron Indian Re: Devilsown Stage 2... 01-27-2009, 10:30 PM
fst Re: Devilsown Stage 2... 03-16-2009, 11:33 AM
Iron Indian Re: Devilsown Stage 2... 03-16-2009, 09:01 PM
Bio248 Re: Devilsown Stage 2... 03-17-2009, 04:48 AM
fst Re: Devilsown Stage 2... 03-17-2009, 06:26 AM
Iron Indian Re: Devilsown Stage 2... 03-22-2009, 10:16 PM
rynoman03 Re: Devilsown Stage 2... 02-13-2010, 07:40 AM
Iron Indian Re: Devilsown Stage 2... 02-14-2010, 10:13 PM
copgtp Re: Devilsown Stage 2... 02-21-2010, 09:37 PM
SgtMarshal Re: Devilsown Stage 2... 03-29-2015, 10:20 AM
fst Re: Devilsown Stage 2... 03-29-2015, 04:18 PM
SgtMarshal Re: Devilsown Stage 2... 03-29-2015, 04:23 PM
  1. #1 Devilsown Stage 2 Progressive Alcohol Injection Install...
    Moore, Oklahoma
    Hey Guys,
    I haven't been on much lately, been working mostly 16 hour days which leaves me pretty much worn out. I had a little bit of time on Saturday and Sunday to get my Devilsown Stage 2 Progressive 3800 Alky Kit installed on my 1999 GTP. Here are my pics...
    Bumper removed ready to get started...
    Theres my washer tank, time for some modifications...
    Nice flat indention, perfect for a fitting...
    Scoring a mark/bit guide...
    Drilling the hole...
    Flushing out the shavings with distilled water...
    Tapping threads into the tank using an 1/8"-27 NPT tap...
    Shawn W. Larsen
  2. #2 Re: hkjljlkkln
    Moore, Oklahoma
    Flushing out the shavings once more...
    Testing the new threads I made...
    Fitting and washer with rubber seal I'll be installing...
    Fittings with some thread sealer and grey RTV which will be used...
    Fitting, washer, rubber seal put together and thread sealer applied...
    A little RTV applied on the washer tank itself, overkill I know, but way not use it too?
    Installing prepped fitting...
    Fitting tightened and ready to go! Note, Elbow swivels too.
    Now its time to run some tubing...
    Starting from the drivers side, i'm running the tubing through the bumper support, going to the passenger side...
    Shawn W. Larsen
  3. #3 Re: hkjljlkkln
    Moore, Oklahoma
    There it is...
    Connected to the washer tank! Be sure to leave plenty of excess tubing, keep in mind, you have some fog light buckets to clear once the cover is back on...
    Now its time to mount the pump and run the tubing to and from it...
    Here's where I plan to mount it, score some marks and drill some pilot holes. The kit comes with self tapping sheet metal screws, but I always prefer drilling a pilot to make the screw go in easier. Its up to you...
    Installing the pump to its new home...
    Mounted and ready to roll...
    Fittings for the pump, I used a little bit of thread sealer before installing. BECAREFUL TO NOT OVERTIGHTEN THE
    FITTINGS INTO THE PUMP, THE BODY IS PLASTIC!!! Note, Elbow swivels too.
    Fittings installed and ready to go, i'll wire it up later...
    Heres my prerun tubing, time to run it to the pump, make sure to pay attention to which way the flow arrows are
    marked on the pump. Be sure to leave excess tubing when mounting the inlet tube.
    Shawn W. Larsen
  4. #4 Re: hkjljlkkln
    Moore, Oklahoma
    Time to run some tubing out of the fenderwell and into the engine bay...
    Now its time to tap a nozzle into the motor. Luckily for me, I already have a TB spacer perfect for this job.
    Bewarned, with my setup it was quite difficult to figure out a GOOD place to mount the nozzle. It took me quite
    awhile looking at it to figure out my best route away from heat and moving linkages...
    TB spacer off the car and on the work bench...
    Time for some drilling...
    Then my handy 1/8"-27 NPT Tap...
    Mocked up DO5 nozzle and 90 degree elbow...
    Shawn W. Larsen
  5. #5 Re: hkjljlkkln
    Moore, Oklahoma
    After several test fits on the S/C with the TB in place I found the perfect angle to mount the nozzle, elbow, and
    check valve. I used thread sealer on all the connections, just to be on the safe side. It certainly doesn't hurt a
    thing. It enters right below the TPS sensor, you'll see...
    TB spacer and TB reinstalled with gasket matched OEM Gaskets with a little bit of Grey RTV to help sealing.
    Shawn W. Larsen
  6. #6 Re: hkjljlkkln
    Moore, Oklahoma
    Now its time to figure out where to place the main control unit for the Devilsown kit. My plan from the begining
    was to mount it in the mini cubby by the headlight switch. I already have a couple of switches mounted, why not a
    control unit too? It should fit perfect. Here it is removed before modification...
    Drilled a hole in the cubby so the control units' wiring can run through...
    Mocking up the control unit in its new home...
    Now its time for some wiring, first we'll start running the wires, control unit, and modified cubby in to the dash
    of the car...
    After running it under the dash and nicely looming and seprating wires, I wired in the supplied 10 AMP fuse holder
    on the red wire power side and I tapped it into a switched 12V source. Since my Acc Power Drop is pretty much used
    up and on the other side of the dash, I used my Autometer Volts gauge power wire as a tapping point and spliced
    there. I took the black ground wire crimped on a ring terminal and used an existing bolt for the steering column
    mount. I proceeded to run the blue and green wires (longest wires in the bundle) to the passenger side wire
    gromment and ran the out into the engine like i've done many times before. After successfully getting the wires
    into the engine bay, I loomed them up and started routing the wires to there new homes. The Green wire goes to the
    MAP sensor and taps into the middle green wire (B) on the connector. The blue wire goes directly to the pump and
    wires into the Red power wire. Posi tap was used for the MAP signal wire connection, a butt connector with heat
    shrink was used on on the blue/red pump connection. For the pumps' ground I used a ring terminal and some shrink
    wrap to seal it off. Drilled a small hole and shot in a sheet metal screw on the frame rail beside the pump.
    Shawn W. Larsen
  7. #7 Re: Devilsown Stage 2 Progressive Alcohol Injection Install...
    Charles City, IA
    Great Write up! I plan to add this kit to my GTP sometime.
    SMGPFC Two Nipple General
  8. #8 Re: Devilsown Stage 2 Progressive Alcohol Injection Install...
    St. Louis Mo.
    Man dude!! That rocks!! Great work and like 01 said, great write up indeed!
    James Shafer
    St. Louis MO
  9. #9 Re: Devilsown Stage 2 Progressive Alcohol Injection Install...
    TDCRacing
    Guest
    Awesome
  10. #10 Re: Devilsown Stage 2 Progressive Alcohol Injection Install...
    TDCRacing
    Guest
    Wanna sell me that scan master Shawn? How much did ya pick it up for or did ya buy it new?
  11. #11 Re: Devilsown Stage 2 Progressive Alcohol Injection Install...
    so youre running completely electrical from the MAP and MAF? i havent really looked at my stuff that much since it's cold as hell and i dont want to work in the cold, but i thought there was a port for a vacuum source too? would that not be easier than running off the MAP?
  12. #12 Re: Devilsown Stage 2 Progressive Alcohol Injection Install...
    i dont follow what you meant by that? i thought the controller only gets tapped into the MAP? does the new kit also reads and tap into the MAF as well?
  13. #13 Re: Devilsown Stage 2 Progressive Alcohol Injection Install...
    im not sure. i havent looked at it in a while since i havent really been trying to install it in the cold. i know there is an electrical connection to the MAP, but is there anything else? i thought there was a vacuum line as well? maybe a MAF connection too?
  14. #14 Re: Devilsown Stage 2 Progressive Alcohol Injection Install...
    o ok, so u werent certain. i have the controller and theres only 3 wires: ground, switched 12v and the wire thats tapped to the map sensor, thats it.
    edit-other competitors like snow performance, IIRC, use the MAF sensor as a base of how much to spray the flow, but they're very pricey
  15. #15 Re: Devilsown Stage 2 Progressive Alcohol Injection Install...
    Bastard Reptile's Avatar
    Kansas City, MO
    Good work Shawn! The install is pretty straight forward, and it's fairly easy if you take your time. The biggest PITA for me was wiring the controller, and making it go through it's diagnostic mode so that I could get it to work.
  16. #16 Re: Devilsown Stage 2 Progressive Alcohol Injection Install...
    Moore, Oklahoma
    Thanks for the compliments guys! I appreciate it!
    The Devilsown kit I have uses the MAP only as reference for the Alky system, nothing else. Otherwise its pretty much self contained. I touched on the wiring subject above, Here it is...
    After running it under the dash and nicely looming and seprating wires, I wired in the supplied 10 AMP fuse holder on the red wire power side and I tapped it into a switched 12V source. Since my Acc Power Drop is pretty much used up and on the other side of the dash, I used my Autometer Volts gauge power wire as a tapping point and spliced there. I took the black ground wire crimped on a ring terminal and used an existing bolt for the steering column mount. I proceeded to run the blue and green wires (longest wires in the bundle) to the passenger side wire gromment and ran the out into the engine like i've done many times before. After successfully getting the wires into the engine bay, I loomed them up and started routing the wires to there new homes. The Green wire goes to the MAP sensor and taps into the middle green wire (B) on the connector. The blue wire goes directly to the pump and wires into the Red power wire. Posi tap was used for the MAP signal wire connection, a butt connector with heat shrink was used on on the blue/red pump connection. For the pumps' ground I used a ring terminal and some shrink wrap to seal it off. Drilled a small hole and shot in a sheet metal screw on the frame rail beside the pump.
    Thats all the wiring needed. No vacuum lines are used either, its all electric.
    Shawn W. Larsen
  17. #17 Re: Devilsown Stage 2 Progressive Alcohol Injection Install...
    Moore, Oklahoma
    Reptile,
    Can you tell me more about this diagnostic mode thing? I don't think I read anything about this in the instruction manual, but its been several days since I looked at it too so I maybe way off. What do I need to basically do? Tips or tricks? Thanks!
    Shawn W. Larsen
  18. #18 Re: Devilsown Stage 2 Progressive Alcohol Injection Install...
    Moore, Oklahoma
    Hell no I ain't selling it, I love it too much!!! LOL!
    Seriously though, I can't remember how much I picked it up for, I got it back in late 2002 or so. I believe it was around $300 back then. Here it is on 3800 Performance for about $320... RamChargers L67 Scanmaster: 3800 Performance
    I also have one in my Black GTP, I got it used off ClubGP about 3 years ago for like $175. Works great too, I wish they made them for every car!
    Ramchargers Scanmaster kicks ass period! They've made them for the Grand Nationals for many years, along with the SY/TY guys, LS1s, and of course the L67s. In fact I knew a guy a few years ago with a Grand National and he had a Scanmaster and IIRC he said his was 12 years old with 0 issues. Hell mine is about 7 years old with about 100,000 miles on it with 0 issues. When my car is on, its on. It's been that way in my cluster since day one. No issues with the black cars Scanmaster either.
    I honestly believe the Scanmaster is one of the if not the best/most reliable realtime scan gauges out there. After seeing all the issues with other ones out there and never seeing or having a problem with a Scanmaster for many years, I think they hold there own quite well.
    I think you should get one Parker, you won't regret it at all. As durable as they are, it will last damn near forever.
    Back to topic, I read on a another post that you're going Alky too, are you going with the same kit I got? If so let me know, maybe we can share tuning info? If you do it , you'll be like 1 of 3 or 4 with Alky + an IC. So far besides Chance, some guy FL, and myself there aren't any IC+Alky guys out there. It will be new territory indeed. Let me know how you're install goes...
    Shawn W. Larsen
  19. #19 Re: Devilsown Stage 2 Progressive Alcohol Injection Install...
    TDCRacing
    Guest
    Cool.
    Yeah i'm working on the new build right now. Not sure if you've seen the thread. So it will probably be a while. But i did think it may be a better alternative than nitrous. I have never heard of anyone blow there car up because of meth lol....Although i'm sure it can be done...somehow.
    I think i will let you test it out and if i like the results...by that time I should be ready...
    But yeah If I do go that route we can def share some files and experience.
  20. #20 Re: Devilsown Stage 2 Progressive Alcohol Injection Install...
    Kansas City, MO
    They might have changed the way you have to wire the controller up, but it was some sequence that you had to do in order to get the ready light to come on. When the kit is armed, the red power light should stay on.
