Flushing out the shavings once more...
Testing the new threads I made...
Fitting and washer with rubber seal I'll be installing...
Fittings with some thread sealer and grey RTV which will be used...
Fitting, washer, rubber seal put together and thread sealer applied...
A little RTV applied on the washer tank itself, overkill I know, but way not use it too?
Installing prepped fitting...
Fitting tightened and ready to go! Note, Elbow swivels too.
Now its time to run some tubing...
Starting from the drivers side, i'm running the tubing through the bumper support, going to the passenger side...
