Quote Originally Posted by trey9778 View Post
I put it all back together but one of the pins on the bottom of the faceplate bent causing the front speakers to fade in and out. Fixed it only to realize when I put it back together the 2nd time a wire from the aux jack was blocking a cd from ejecting so I took it apart again fixed that then realized my screen went dark. The light bulb must have fried from all the moving around. So I tried to remove the light bulb and replace it but broke the soldering points on the circuit board.
Yeah you have to be careful with really anything electronic. Good luck on finding another one though. The JY one I have is messed up, turning the volume up or down isn't a guarantee, it will go up or down no matter which way you turn it. It decides.
I would have used heat shrink instead of duct tape, but nice write up!
It's electrical tape.
And thanks guys
