Thread: How to Install a DIY aux Input Jack in a 97-03 Radio
Results 1 to 20 of 61
  1. #1 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Dec 2012
    Where 4T65E's were born
    Been done before lots of times... there was an official how to writeup a long time ago. I can't find it, so its likely been lost along the way.
    This is a nice mod, I have done this myself. Good pics and information, thanks for doing it!
    ONLY 1 THING TO ADD!!! You need to include information regarding the optional ribbon cable that was used in radios. My 7-way EQ Radio in my 99 looks just like yours except I had to splice into a ribbon cable, not easy wires like yours was. Makes it a PITA. Still similar setup, but some people would likely be commenting and questioning where to splice when that connector doesn't exist in theirs.
    No problem. Yeah I couldn't find one here either.
    I'll look into the ribbon cable version. What scotty said works though. My first time doing this mod something happened to the connector and it had to be soldered straight to the board. Worked just as good. I wonder if they're "swapable" where you could get yourself a wire style and just use it instead. Probably not as every ribbon cable I've ever seen has paper thin contacts at the end.
    Quote Originally Posted by Nates94 View Post
    I don't like splicing into ribbon cables. I guess when I'm at the yard I should pull a 7 way EQ radio and check for that.
    Good write up. I hope to be able to do this sometime this winter.
    Would be a lot harder to make the wires on the AUX jack and run it into the center console? Do you think longer wires would have a negative impact on the sound quality?
    You can always pull your faceplate to check.
    It's really not much harder to run it in a different location. It just takes some Ethernet cable and remembering the different wires and where to put them. It also requires an additional hole in the back of the head unit, not hard to do though. Longer wires using Ethernet (which is a low resistance wire), seemed to have no effect on the sound.
    Sold.
  1. How to add a line input jack on 04+ with XM
    By OH4CompG in forum How To Write-Ups/Tech Tips
    Last Post: 05-28-2013, 10:55 PM
  2. Is there a factory radio that will bolt in with an Aux jack?
    By My427stang in forum Audio, Security & Visual Electronics
    Last Post: 11-26-2012, 06:39 AM
  3. 2001 stock radio adding mp3 jack
    By 2001goldGTP in forum Audio, Security & Visual Electronics
    Last Post: 11-28-2011, 03:17 PM
  4. '08 With Factory XM Auxillary Jack Install
    By RealMcCoy in forum Audio, Security & Visual Electronics
    Last Post: 03-30-2011, 05:40 PM
  5. Radio Aux input Jack Install (How To)
    By JJ91284 in forum Audio, Security & Visual Electronics
    Last Post: 08-25-2010, 11:19 AM
