Thread: How to add a line input jack on 04+ with XM
Results 1 to 20 of 23
  1. #1 How to add a line input jack on 04+ with XM
    Portland Oregon
    Credit for this write up goes to a member on seaclubgp.com. I will be doing this mod myself next month.
    The $2.74 MP3 Jack For 2004 - 2008 Pontiac Grand Prix with XM Radio
    Posted: Tue Apr 21, 2009 11:53 am • Rate Post
    OK, you don't need XM Radio activiated for this modification to work. This allows you to add a 1/8" stereo jack that when plugged in, bypasses the XM radio signal and allows you to listen to a MP3 player, DVD player, etc. etc. through your stereo.
    Here is what you need:
    1) Radio Shack part number 274-264, 1/8" stereo headphone jack
    3) Electrical tape or heat shrink tubing
    4) Package of small wireties
    5) Some small gauge hookup wire, 20 to 22 gauge will work best
    Tools:
    1) Wire cutter and stripper
    2) Drill (darn it I don't remember the drill bit size) for one mounting hole
    3) Kitchen butter knife
    4) Soldering iron and solder
    5) Phillips screw driver or small socket wrench set
    STEP ONE: You need to remove the center stack cover from the dashboard. First, take a butter knife and pry off the trim ring around the ignition switch. Be careful not to scratch your dashboard. Second starting at the top, simply pry away the cover, it comes off easily. This exposes the air vent, your head unit, the climate control module and the storage bin. You can unplug your DIC without impact to the car.
    STEP TWO: Remove the head unit, climate control module, and storage bin. All are held in by simple screws, easily done in just a few minutes. The way it is designed you can't remove the head unit without removing the entire stack, they lock into each other.
    STEP THREE: Unplug the smaller 12 wire wiring harness from your head unit, this is the XM/auxilary connection into the stereo system. We're going to be cutting two wires and stripping some insulation from a third.
    a) The brown/white wire is for the left audio channel - cut
    b) The green/white wire is for the right audio channel - cut
    c) The black/white wire is the ground wire - strip insulation to expose wire
    Make sure that you don't cut too close to the plug so you have enough room to strip some wire and make the reconnection, at least one inch.
    STEP FOUR: I found it was easier to build a wiring harness and solder it to the stereo jack and then splice it into the Grand Prix wiring, then trying to solder it all in the car. Using the numbers for the pin positions from the wiring diagram that comes with the jack from Radio Shack:
    Pin 1: Common/Ground
    Pin 2: Left INPUT
    Pin 3: Left OUTPUT
    Pin 4: Right OUTPUT
    Pin 5: Right INPUT
    I just soldered the connections on. The connections are very small on the jack so the smaller the gauge of the wire the better. I made the wire three feet long which was total overkill, but made it easy to mount. I then put wireties every 2 inches along the fire wires and snipped the ends off.
    STEP FIVE: You're almost done, time to connect it all together
    Pin 1 Wire: Connect to the stripped black/white common ground wire, solder or otherwise secure.
    Pin 2: Connect to the RADIO SIDE of the wiring harness on the brown/white wire
    Pin 3: Connect to the XM SIDE of the wiring harness on the brown/white wire
    Pin 4: Connect to the XM SIDE of the wiring harness on the green/white wire
    Pin 5: Connect to the RADIO SIDE of the wiring harness on the green/white wire
    STEP SIX: Time to test! If you disconnected all connections to the stereo reconnect and put key in ignition to accessory. Make sure that your AM/FM, CD and XM radio still works. Check wiring if there is an issue. Set your radio to XM, XM does not need to be activated and it won't matter what station you're on if you did your wiring right. Now plug in an MP3 player, DVD player, etc, into the jack. Pick a song, you'll probably have to turn the volume up to get enough signal (I have a Zune and I have to set it to maximum volume to be equal to the XM level). TADA! You now have a successful input jack. Remove the plug and XM radio starts playing again.
    STEP SEVEN: Mount the jack. I mounted mine to the right of the center air vent. There is a lot of empty space behind that part of the dash. I drilled a small 1/16" pilot hole and then drilled successively larger holes until I found the right size hole, testing each time, drill too big and the jack won't mount. Here actually is the hardest part. You're going to have to shave a bit of plastic from the interior side of the cover (the side you don't see) as the neck for the 1/8" jack is not long enough to get through the plastic and allow the mounting nut to grab onto the threads. I carefully shaved with a razor blade for about 20 minutes, checking as I went until I had enough thread for it to bite, and turn about two revolutions. Now just put everything back together. You should have a nice clean 1/8" stereo jack somewhere in your dash, otherwise it all looks stock and factory.
    This modification works on almost all GM vehicles that have XM radio installed.
    Hope everyone is well.
  2. #2 Re: How to add a line input jack on 04+ with XM
    Houston, TX, USA
    Cool guide. But any idea how to do it without the equipped XM? Discussion here http://www.grandprixforums.net/using...ped-40455.html thank you.
  3. #3 Re: How to add a line input jack on 04+ with XM
    Portland Oregon
    I'm not 100% sure to be honest with ya. This is a copy paste from a member of Seattle Club GP that did it on his XM equipped car.
  4. #4 Re: How to add a line input jack on 04+ with XM
    Houston, TX, USA
    Can you link me to where this is from?
  5. #5 Re: How to add a line input jack on 04+ with XM
    SE Level Member RealMcCoy's Avatar
    Jun 2010
    Central WV
    All our radio shack had was this part number, but it had 3 prongs, not 5. My stepdad used to be a wiring king and he says that the 3 prong won't work... that it will blow the finals out of the head unit.... so I need help finding a part that will work. Thanks. I tore everything out today and had my homemade harness made, but it looks like it isn't gonna work?
  6. #6 Re: How to add a line input jack on 04+ with XM
    Houston, TX, USA
    Look harder they should have the 5 prong
  7. #7 Re: How to add a line input jack on 04+ with XM
    Jun 2010
    Central WV
    I've been to every Radio Shack in an hour radius and even one 4 hours away (visiting family there, not just to go to RadioShack). Looks like no one is stocking these. I am gonna do a last ditch effort and order from their website and hope it comes a 5 prong. Thanks.
  8. #8 Re: How to add a line input jack on 04+ with XM
    Houston, TX, USA
    Don't go by the part number, just search the drawers more thoroughly. If you still can't find it either order it online or search for it at a different parts place like frys or something.
    Please let me know if you get it working, I got the part I needed but I haven't gotten it to work yet.
  9. #9 Re: How to add a line input jack on 04+ with XM
    Jun 2010
    Central WV
    Finally got this jack via FedEx several days late today. Ordered it from their website. Gonna solder the harness onto the jack tonight... then solder into the car tomorrow.
  10. #10 Re: How to add a line input jack on 04+ with XM
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    Hmm, I wonder if this will work with the factory HU with Nav...
    Any ideas? It still has XM..
  11. #11 Re: How to add a line input jack on 04+ with XM
    Jun 2010
    Central WV
    Well I got it working, no problems.... Wanted, did you check your solders and for loose connections? Does the jack you have have a clear window on it so you can see the action to know for sure when you plug in a jack it is BREAKING a connection and MAKING a new one?
    And sorry to state the obvious, but none of your wires are touching are they? I'm sure you insulated each one separately...
    The mistake I almost made was cutting into the tan wire instead of the brown and white one... I don't know what else to tell you as far as troubleshooting.
    Koniig... if it has the XM, does it have the separate harness of like 5 wires? If it does I don't see why it wouldn't work but don't know...
  12. #12 Re: How to add a line input jack on 04+ with XM
    Niles, MI
    I went looking for the 1/8 headphone jack using the part# stated and could find it but I did find it as part# 274-246. Here is the link
    1/8" Stereo Panel-Mount Phone Jack - RadioShack.com#
    please let me know if this is the correct headphone jack.
    Thanks, Rick
  13. #13 Re: How to add a line input jack on 04+ with XM
    SE Level Member tankrc's Avatar
    warren, ohio
    Did in my 07 and works great! took about an hour to do.
  14. #14 Re: How to add a line input jack on 04+ with XM
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    I just did this install on my 08 gxp and everything sounds good and works fine regarding the jack and xm. My only issue is now half of the display on the radio is dim. I unhooked the xm plug and tried again, but the light is still dim. Do you think this is related to the install, or is it one of the bulbs inside the radio got jarred or something during r&r? I've had this car less than a week and prior to this install the radio light worked.
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  15. #15 Re: How to add a line input jack on 04+ with XM
    Jul 2010
    Detroit
    I just want to update. The install had nothing to do with the light going out. The dealership replaced the radio under warranty and all is good. It was simply a burned out bulb.
    SN: As previously stated above, The correct part # is 274-246
    Last edited by mrlogic1234; 12-24-2011 at 11:34 PM. Reason: added part # confirmation
    Ryan
  16. #16 Re: How to add a line input jack on 04+ with XM
    SE Level Member DCGTP's Avatar
    Charleston SC
    I wish i had done this on my comp g earlier! super easy and cheap. easily going to be my favorite mod.
    koniig: i have the factory nav with xm, exactly the same procedure as listed above.
    Overkilled, AL605s, 180 T-stat, Cone Intake, Cross drilled & Slotted Rotors, f-body upgrade, poly upper mounts, shorter dog bones,
    factory nav, 2x12s in the trunk, interior LED swap, all 5000k HIDs, red halo's in upper grille, tinted tails and reverse lights, de-badged, XM to line in conversion
    SE Level Member RICHEYSGTP's Avatar
    Oct 2012
    Indiana
    Anyone have pics of their install ?
  18. #18 Re: How to add a line input jack on 04+ with XM
    Yoga city
    look at this on: http://www.grandprixforums.net/how-d...ars-64293.html
    Quote Originally Posted by RICHEYSGTP View Post
  19. #19 Re: How to add a line input jack on 04+ with XM
    Charleston SC
    this install does not run from the trunk it runs from the center console behind the head unit. i have an input plug about an inch above my head unit to the right, slightly under the AC vent.
  20. #20 Re: How to add a line input jack on 04+ with XM
    Jul 2010
    Detroit
    [IMG]
    Ryan
  1. Jack Point / Location
    By american_kestrel in forum Off Topic Discussion
    Last Post: 10-01-2017, 01:12 PM
  2. Where's the best place to jack up the car?
    By bronzegp in forum Tires & Wheels
    Last Post: 06-02-2009, 09:49 PM
  3. Jack, Or No Jack?
    Last Post: 12-14-2008, 07:30 AM
  4. Looks Like I'm The New Jack...
    By Billyb in forum Introductions/Noob Questions
    Last Post: 08-24-2008, 08:35 PM
  5. Certain Feds want to jack up fuel taxes.
    By Reptile in forum Off Topic Discussion
    Last Post: 01-17-2008, 09:22 AM
