Thread: How to Install a DIY aux Input Jack in a 97-03 Radio
Results 21 to 40 of 61
  1. #21 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    I live here. TLSheff's Avatar
    It should be. Most of them were very similar inside, you just have to identify the wiring connector. Its usually either the wires like pictured above, or a ribbon cable.
  2. #22 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Nov 2010
    Ray MI
    Quick question. How much of the radio did you have to take apart to get the amp/cd cable? Did you only remove the faceplate?
    1991 Grand prix GT
    1994 Cutlass Supreme
    2000 Grand prix GTP
  3. #23 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Dec 2012
    Where 4T65E's were born
    Yup the faceplate has to come off, then the faceplate itself has to be separated only if you're mounting it inside it.
    Sold.
  4. #24 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Nov 2010
    Ray MI
    Alright got it. I want to go the yard tomorrow and pull some radios and see if I can find one without ribbon cable. I didn't know how far I had to take the radio apart to find out. Thanks.
    1991 Grand prix GT
    2000 Grand prix GTP
  5. #25 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Dec 2012
    Yup. I'm not sure how the theftlock works but keep that in mind.
    Sold.
  6. #26 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Nov 2010
    Ray MI
    That's a good point. I have unlocked a GM radio before.
    1991 Grand prix GT
    2000 Grand prix GTP
  7. #27 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Dec 2012
    Special phone # and code?
    Sold.
  8. #28 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Nov 2010
    Ray MI
    Yup, it's been a while, but had to do it years ago when my first GTP's battery went dead and I had to un LOC the radio.
    1991 Grand prix GT
    2000 Grand prix GTP
  9. #29 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Jun 2011
    Texas
    I've done this a couple of times on both the ribbon style and individual wire style. Here is what I did on the ribbon style:
    I cut the ribbon to separate the individual circuits and tapped off the right and left channels.
    Then plugged it in.
    I found a place to solder a wire into the right and left circuits.
    I soldered into the right and left circuits on the bottom side of the radio board.
    I installed the AUX jack just to the right of the EQ. I had to make the plastic face thinner with a dremel.
    No modification of the circuitboard was required to get the AUX jack to fit in this location.
    The finished product.
    As a note, on both of the radios that I did the mod on the display bulb went out within a month or so. In the future I will replace the bulb during the mod. The bulb is available from GM. The part number is 16208443. Last time I checked it was cheaper to get it from your local dealer than from an online store (amazon, rockauto, etc).
  10. #30 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Dec 2012
    Thanks for the info! it will help the people out with this style. My display bulb burned out as well when I did the mod, I've got the part # in the op too.
    Sold.
  11. #31 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Curious, would that bulb number be the same for a 2002 bonneville?
    Both bulbs in the bonnie are burnt out and see some fixin when it's warm out.
  12. #32 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Dec 2012
    I'm not sure. I would think GM would use the same bulb since most of their radios are very similar inside. You'd have to take a look at it unless someone else knows, maybe look up the mod for Bonnevilles
    Sold.
  13. #33 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    GTP Level Member GrandPrixgtp2000's Avatar
    Madrid Iowa
    Do you have to have a cd in for this to work?
  14. #34 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    http://ls1tech.com/forums/stereo-ele...dapter-26.html post 505 and 507. guy used the radio wires
  15. #35 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Dec 2012
    Quote Originally Posted by GrandPrixgtp2000 View Post
    I do. I leave one in there, and hit the cd button and it plays the aux jack audio (when it's plugged in). It will play the cd if it's not plugged in.
    Sold.
  16. #36 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Nov 2010
    Ray MI
    Looks like I will be doing this again on another radio.
    1991 Grand prix GT
    2000 Grand prix GTP
  17. #37 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Dec 2012
    On the t bird? Lol
    Sold.
  18. #38 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Nov 2010
    Ray MI
    On the t bird? Lol
    That too, LOL The radio in my GTP just up and died out of no where. I have been driving the CS the past few days and I don't mind. Just too cold for a convertible and not enough snow for the AWD Escape.
    Nah, for the T'bird I plan on buying on these, It's a few hundred bucks, but it will worth it.
    1991 Grand prix GT
    2000 Grand prix GTP
  19. #39 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Dec 2012
    Those are pretty cool. They make nice ones for mustangs too
    This isn't my uncles mustang, wish it looked that good inside though
    Not sure if you can see it, but the radio has the mustang emblem on it. It looks completely analog and am, but when turned on there's a digital FM display.
    Sold.
  20. #40 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I installed my aux jack similarly, and I found that I physically needed a CD in the CD player for it to play. Not sure what I did differently than you.
    I just keep a blank CD-R in my car for when I want to use my MP3 player.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  1. How to add a line input jack on 04+ with XM
    By OH4CompG in forum How To Write-Ups/Tech Tips
    Last Post: 05-28-2013, 10:55 PM
  2. Is there a factory radio that will bolt in with an Aux jack?
    By My427stang in forum Audio, Security & Visual Electronics
    Last Post: 11-26-2012, 06:39 AM
  3. 2001 stock radio adding mp3 jack
    By 2001goldGTP in forum Audio, Security & Visual Electronics
    Last Post: 11-28-2011, 03:17 PM
  4. '08 With Factory XM Auxillary Jack Install
    By RealMcCoy in forum Audio, Security & Visual Electronics
    Last Post: 03-30-2011, 05:40 PM
  5. Radio Aux input Jack Install (How To)
    By JJ91284 in forum Audio, Security & Visual Electronics
    Last Post: 08-25-2010, 11:19 AM
