Thread: Crankshaft Position Sensor Replacement [*]
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 84
  1. #61 Re: Crankshaft Position Sensor Replacement [*]
    Why not change it yourself. It's literally a 30 min job just takes a trip to lowes or Home Depot and picking up the correct bolts and then renting a harmonic balancer pulley from autozone. No sense in paying a mechanic for something so easy.
    04 Comp G.
  2. #62 Re: Crankshaft Position Sensor Replacement [*]
    Dec 2008
    Essex, UK
    Erm...in case you haven't noticed, I'm in the UK, haha! I've also got mobility problem so can't work on my car too much anymore.
  3. #63 Re: Crankshaft Position Sensor Replacement [*]
    Sure haven't lol can't see your location from tapatalk my bad
    04 Comp G.
  4. #64 Re: Crankshaft Position Sensor Replacement [*]
    Do you have a set of jackstands? This is a super easy thing. Even if you don't have air tools. You can do it by hand.
  5. #65 Re: Crankshaft Position Sensor Replacement [*]
    Dec 2008
    Essex, UK
    Unfortunately not, even if I did I could not physically work on it.
  6. #66 Re: Crankshaft Position Sensor Replacement [*]
    Mar 2013
    St. Louis
    So is the crankshaft oil seal right behind the harmonic balanced? Is it just a pull off and put new one on deal?
    Sent from my SPH-L710 using Tapatalk 2
  7. #67 Re: Crankshaft Position Sensor Replacement [*]
    In the How to I wrote up, you can see the green/orange seal. It's directly behind the balancer.
    http://www.grandprixforums.net/how-r...sor-60906.html
  8. #68 Re: Crankshaft Position Sensor Replacement [*]
    Mar 2013
    St. Louis
    Awesome. And that just pulls off and goes right back on?
  9. #69 Re: Crankshaft Position Sensor Replacement [*]
    It's a pain in the buns to get out with it in the car as opposed to being on a workbench. It's possible though. Put a light bead of RTV around the outter edge of it where it'll get pressed in the casing. Then tap the new one in place. Also I'd suggest lightly touching the surface of the harmonic balancer where the seal makes contact. Say a green scrub pad.
  10. #70 Re: Crankshaft Position Sensor Replacement [*]
    Mar 2013
    St. Louis
    What type of rtv?
  11. #71 Re: Crankshaft Position Sensor Replacement [*]
    Mar 2013
    St. Louis
    and what do you mean on a workbench? What exactly would be on the workbench?
  12. #72 Re: Crankshaft Position Sensor Replacement [*]
    i think hes talking about tapping the new seal in the hole. it needs to go in just right, you cant dent the edges or it will leak.
  13. #73 Re: Crankshaft Position Sensor Replacement [*]
    First off...I live on Ultra Copper RTV. It's the only one allowed in the toolbox. Does everything well.
    On the workbench, as if I had the front cover off the motor and laying on a workbench. Makes it easy to see/feel/do anything when you aren't in a confined area. To get the seal in..find something around the place to use as a driver. Something the same size around that you can tap on to drive the seal in place.
  14. #74 Re: Crankshaft Position Sensor Replacement [*]
    Mar 2013
    St. Louis
    Gotcha. Thanks alot. Unfortunately ill be dealing with it on the car so ill jjust be sure to be careful.
  15. #75 Re: Crankshaft Position Sensor Replacement [*]
    for the record..that is my workbench under this cover.
    And that'd be a spare charger casing next to it
  16. #76 Re: Crankshaft Position Sensor Replacement [*]
    Mar 2013
    St. Louis
    Well ill be damned! Got the wheel off, started it and its coming right of the plug on tthe oil sending unit. Steady stream of oil. I guess I should look into things before I start assuming stuff!
  17. #77 Re: Crankshaft Position Sensor Replacement [*]
    Pair of pliers and you are all set for tools. Nice!
  18. #78 Re: Crankshaft Position Sensor Replacement [*]
    BTW, that's Scott's favorite fix.
  19. #79 Re: Crankshaft Position Sensor Replacement [*]
    change that pos right away, they leak bad when they blow out all the way. its a 12 dollar part, but keep an eye on it, i went through 3 of them, from every parts store here. i now have a brass 60 cent plug in the hole, sick of changing it.
    channel locks work great to take it out, dont drive the new one in to far, stop when its snug, and into the thread locker on the new sensor threads.
  20. #80 Re: Crankshaft Position Sensor Replacement [*]
    3 times is a charm, hate that thing lol
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  3. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
  4. New CHEAP upgrade MAF sensor!!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 12-27-2007, 12:56 AM
