well, Here's what I got.
My '04 GP, no SC. I've disconnected the following:
main motor mount attached to the infamous U-bracket, the rear motor mounts (passenger side 15mm nut, 16mm head, driver had 18mm nut and head) both sides of the sway bar, both rear cradle mounts. I've tried to disconnect the front cradle nuts, but it seems as if the bumper support is under the cradle, not the other way around. Not sure how the front is going to drop out unless I take the wheel well skins off and find a nut in there. No AC compressor removal yet, but it looks imminent. Engine is supported both front and rear engine supports by a support bar going parallel with the engine.
I'm just not sure how the subframe drops out. If I let the frame go with the jack, the engine drops too far down. Maybe I need to take up some slack on the engine. If I support the engine more with the jack, the subframe just doesn't go anywhere to make the u-bracket any easier to get to.
HELP!!!!- TIA
