Thread: Oil pan removal: my how-to, my hell
Results 21 to 40 of 52
  1. #21 Re: Oil pan removal: my how-to, my hell
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Been thinking of doing this for a while, but honestly I dont want the headache. If i get one of my buddies to help me, i may knock it out. Otherwise, i'll probably take it to the repair shop. Hopefully they dont charge me out the ass with those AllData or Mitchell prices. Good write-ups though, I will definately refer to this thread......
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
    GT Level Member glendayle's Avatar
    Salt Lake City
    I think the job is coded at like 4 hours or something. Dealership quoted me about 480 or something like that. For this reason i bought some tools and did it myself.
    Sent from my SPH-D710 using Tapatalk 2
    1999 Regal GS Mods-180 tstat; CAI FWI; ubend delete/3"DPCB PLOG; HID fog conversion, 3.5, tint(42%/20%), TK Trans 3.29 gears
  3. #23 Re: Oil pan removal: my how-to, my hell
    Jul 2012
    North Philly
    Bout to go H.A.M.[IMG][/IMG]
  4. #24 Re: Oil pan removal: my how-to, my hell
    HUDSON
    I also have a leaking pan gasket, and the steel oil pan has some rust on it, so instead of buying a replacement steel pan and gaskets, I went ahead and aquired the parts for an aluminum pan since I have to replace the pan anyways. For the price of the aluminum pan was not much more than a steel pan and gasket, althouth the extra cost of the bracket and oil pickup tube was not too bad. I also get the benifit of the ease as installation by not having to reinstall the "U" bracket and the 4 hard to get too bolts.
    Also, thanks to those who posted the part numbers for the conversion to the aluminum oil pan!
    Just waiting for some cooler weather to do the swap!
    Salt Lake City
    Quote Originally Posted by QUICKSILVER462 View Post
    Might as well pick up an aluminum cradle while you are at it.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Can u post a link of that thread for the aluminum part numbers and required parts for the job I can't seem to get to search to work on my phone
    Sent using my Galaxy SIII on Tapatalk
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  7. #27 Re: Oil pan removal: my how-to, my hell
    RTV for gasket, aluminum pan, pickup tube from the same year car that came with the Al pan.
  8. #28 Re: Oil pan removal: my how-to, my hell
    Jul 2012
    North Philly
    Nice....the aluminum oil pan is a nice touch.....
  9. #29 Re: Oil pan removal: my how-to, my hell
    HUDSON
    Pan (part# 12597244_
    Pickup tube (part# 24506437)
    Mount bracket (part# 10345562)
    Mount (old one should work)
    Small tube of GM engine sealant (no gasket on these pans)
    YI...Pan Number is 12597244
    Pan: 12597244
    Pickup: 24506437
    Bracket: 10345562
    2004 gp or lucerne with 3800
    If you get a lucerne..there is no bracket so it's part number 10345562 bracket eng mt
    Engine Oil Pan
    Grand Prix 2005-2007 W(L32)
    Grand Prix 2005-2008 W(L26)
    Lacrosse/Allure 2005-2008 W(L26)
    Lucerne 2006-2008 H(L26)
    The Above is info I have collected here for the pan swap, it was compiled from sources I cannot remember, but thanks to them Hope it helps you, it helped me.
    Oct 2011
    MI
    AWESOME!
    Mines an 04 comp g.. kinda confused me on the lucerne... is that what car the aluminum pan is part listed from?
  11. #31 Re: Oil pan removal: my how-to, my hell
    Jul 2012
    North Philly
    Im curious of what the pickup tube looks like in our cars after a good 10-15yrs.....probably not that bad if well maintenenced, but i can imagine that its not perfectly clean at all.....
  12. #32 Re: Oil pan removal: my how-to, my hell
    If it was me..you are welcome ...lol You will love that pan. Matt..it's GM engine sealant, not regular RTV. RTV would probably work, the sealant though..much better stuff.
    Dee: It looks like a pickup tube.... not the same as the AL pan though.
  13. #33 Re: Oil pan removal: my how-to, my hell
    Ultra grey RTV is what many japanese manufacturers spec for their oil pan seals.
    If anyone is replacing their pickup tube, I might suggest a Melling pickup tube. The F body pickup is larger. Unsure on the W body. Someone will have to buy it and compare.
    On the cleanliness. You'd be surprised. If you are up on your oil changes you can have a very clean engine.
  14. #34 Re: Oil pan removal: my how-to, my hell
    Jul 2012
    North Philly
    Naw Bill, I know what the pickup tube looks like......i was referring to how dirty, clogged, gunked, and damaged it possibly could be after 10-15yrs.....
    Im just curious of what it looks like after all these years and if it still has good flow......
  15. #35 Re: Oil pan removal: my how-to, my hell
    Dee...Let's analyze that.
    If the pickup tube was gunked or clogged, you'd have no oil pressure, your motor would have killed a bearing or so by now. If you do oil changes reasonably..then your motor should be clean inside. If you neglect..you'll have a light build up of crud. When I do LIM gaskets or VC gaskets on a car, I can tell how often the owner changes oil.
  16. #36 Re: Oil pan removal: my how-to, my hell
  17. #37 Re: Oil pan removal: my how-to, my hell
    That isn't dirty..that's brutal.
  18. #38 Re: Oil pan removal: my how-to, my hell
    Jul 2012
    North Philly
    I hear u Bill....trust me, I understand all that. it was just a random thought for any motor out there. Like u said routine maintainence defines it all. i change my oil so often, its not even funny. In the last 10k miles, ive changed my oil 3-4 times and thats with Castrol Titanium...yeah thats overkill, and expensive, but i love my motor and can guarantee that biittccchhh is clean inside out...LOL
    But i did buy a new pickup, bc the previous owners didnt know how to lift a vehicle so take a wild guess....yes, the oil pan is dented in about 2-3 inches all the way across. Now im changing the pan and everything, i didnt want to get to deep in the process and find the pickup to be slightly bent or damage and not have a new one to replace it. So, i just bought a new one to be prepared.....
  19. #39 Re: Oil pan removal: my how-to, my hell
    Jan 2013
    Phoenix
    Thanks for the wright up on this oil pan removal. Everything was just as you said. I do have a suggestion that should help in the install and any future disassembly. Before I put the Infamous U bracket back on I created a slit in the 3rd hole on the firewall side of the U bracket. Putting that last screw in with the oil pan off the car is much easier than with it on. By putting the slit in the bracket you can start the screw first than slide the U bracket up and install the other screws by the air compressor etc. By putting that slit in the bracket I could install it in less than 10 min.
    I hope that helps. Hack saw and hand grinder to create the slot was less than 10 min. I found it was much easier to remove the air compressor than fight the clearence issues.
  20. #40 Re: Oil pan removal: my how-to, my hell
    SE Level Member TallTexan's Avatar
    Houston, TX
    I did this recently following Glendayle's write up using a bottle jack to support and lift the engine from below. Recommend that you go ahead and buy a double offset 15mm wench because there is one bolt that's near impossible to remove without it. I also had to butcher up another 15mm box/open end wrench by grinding off the open end part. This is so I could extend it long enough to remove the bolts between the engine and transmission using short piece of 1/2" emt metal pipe over the cut off end. A standard length wrench just did not stick far enough down for me to get enough torque on it to remove those bolts.
    The other hard part of the job was reassembly and blind aligning/screwing the bracket bolts back into the engine. One more tip: I also completely unbolted the A/C compressor and moved it out of the way (leaving the hoses still connected).
    Now my son's '05 Impala SS has just started to leak oil in the pan area. So I/we will be doing this all over again.
  1. What the hell?
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 08-09-2011, 11:46 AM
  2. Hell yes!
    By whitehead in forum Off Topic Discussion
    Last Post: 08-03-2011, 01:20 AM
  3. dtc's from hell
    By sca555 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-09-2011, 05:44 PM
  4. Where the hell did this car go?
    Last Post: 09-09-2008, 09:30 AM
