Thread: Oil pan removal: my how-to, my hell
Results 1 to 20 of 52
Threaded View
  1. #7 Re: Oil pan removal: my how-to, my hell
    GT Level Member glendayle's Avatar
    Salt Lake City
    I lower the cradle(step 4 in my writeup, but I don't remove it. I just get an extra few inches of clearance to do it this way), but you do not need to remove the AC compressor to reach the front MM bracket bolts. Although if you have trouble imitating gumbi it might be easier to remove it. I usually loosen it with deep double offset wrench and then put my arm through the passenger wheel well to remove it. It's a tight fit though. You can also reach up and over/around the compressor from below but again, it's not a position I like.
  1. What the hell?
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 08-09-2011, 11:46 AM
  2. Hell yes!
    By whitehead in forum Off Topic Discussion
    Last Post: 08-03-2011, 01:20 AM
  3. dtc's from hell
    By sca555 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-09-2011, 05:44 PM
  4. Where the hell did this car go?
    Last Post: 09-09-2008, 09:30 AM
