Thread: How to change coolant elbows
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 93
  1. #61 Re: How to change coolant elbows
    GT Level Member grandamle91's Avatar
    Jun 2011
    Watertown, SD
    The casted ones were mainly on Buicks, and Olds. At least that's all I've seen them on
    2000 GP GT 3.8 NA Stock Engine - Cat, EGR Deleted - K&N Cone - Pulstar Pulse Plug ad1h10 -6k HIDS- LEDS
  2. #62 Re: How to change coolant elbows
    Quote Originally Posted by grandamle91 View Post
    you see them on every 96-98 w body with a 3800 of any make or model.
  3. #63 Re: How to change coolant elbows
    Banned
    Jan 2013
    Colorado
    does this tensioner come out if you pull the motor?
  4. #64 Re: How to change coolant elbows
    nope.
  5. #65 Re: How to change coolant elbows
    Banned
    Jan 2013
    Colorado
    oh really? Well i guess if the motor is out, it will be easier to get to it.
  6. #66 Re: How to change coolant elbows
    for sure. you can see what going on better.
    you dont want to pull it on a any angles really or the timing cover can break. keep it level and a little wiggle left and right while pulling it to the fender.
  7. #67 Re: How to change coolant elbows
    Banned
    Jan 2013
    Colorado
    the motor or the elbow?
  8. #68 Re: How to change coolant elbows
    think about where the timing cover is then check back with me......
  9. #69 Re: How to change coolant elbows
    Banned
    Jan 2013
    Colorado
    I haven't gotten a chance to look to in depth at this engine yet. In fact I haven't seen it in the day light yet.
  10. #70 Re: How to change coolant elbows
    that cast elbow goes into the timing cover, if you dont pull the alt bracket off straight the timing cover cover coolant inlet hole will break. then your changing the timing cover on the engine.
    this is why its just a little wiggle as you pull it off. this can seem like its taking forever, walk away, take 5, come back to it if need be.
    once its off, clean the 3 holes out good and the cast elbow, take the new O ring off the new elbow your not using and put it on the cast elbow. re install it with a new upper elbow.
  11. #71 Re: How to change coolant elbows
    Jun 2011
    Watertown, SD
    My 97,98 Grand Prix Doesn't have the cast
  12. #72 Re: How to change coolant elbows
    Banned
    Jan 2013
    Colorado
    might change it anyway though since when I pull the motor I'll be replacing the cam amongst many other things
  13. #73 Re: How to change coolant elbows
    it has to come off in that case. its in the timing cover. and thats coming off to install a cam
  14. #74 Re: How to change coolant elbows
    Banned
    Jan 2013
    Colorado
    thanks, wanna try and find an aluminum subframe for me?
  15. #75 Re: How to change coolant elbows
    thats your job pal. leg work, get to it lol
  16. #76 Re: How to change coolant elbows
    All 3800's came cast from 97 and 98. If yours doesn't have it.. then it had an F body one. Because that one got two plastic elbows from the start.
  17. #77 Re: How to change coolant elbows
    Aug 2012
    Santa Cruz
    a 97-98 bracket, see the lower cast elbow on the bottle left of the part? thats the cast elbow
    Ohh ohk, now I see! Thanks
  18. #78 Re: How to change coolant elbows
    Southeast PA
    I assume this is just as easy for us supercharged folk, correct? Just a bit more finesse around the s/c is required?
    '06 GT S/C - F-body brakes
  19. #79 Re: How to change coolant elbows
    same job....only your taking the sc belt off to get the other belt off.
    what finesse? its not in the way at all.
  20. #80 Re: How to change coolant elbows
    Southeast PA
    Awesome, thanks for the info. Haven't really looked under the hood to check yet. Car is in for inspection and they called me and mentioned a coolant leak at one of the elbows. Also said it could take them 2hours because the supercharger. But they seem to be full of s***. Looks like well less than an hour to me. Will tell them to leave it be and I will fix it myself.
    I will finally flush and switch to the green coolant while I am it. Get rid of that sloshing hopefully, too.
  1. Need to replace coolant elbows
    By Posty101 in forum Engine
    Last Post: 06-02-2011, 02:22 PM
  2. coolant elbows
    By noreasonwhyy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2010, 05:56 PM
  3. How do you replace the coolant elbows?
    By Mercenary in forum General Tech Discussion
    Last Post: 07-19-2010, 06:50 PM
  4. Coolant elbows
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 12-01-2009, 11:58 AM
  5. Coolant Elbows for 2000 GTP
    By nickbuol in forum General Tech Discussion
    Last Post: 07-21-2009, 10:51 PM
