The casted ones were mainly on Buicks, and Olds. At least that's all I've seen them on
does this tensioner come out if you pull the motor?
nope.
oh really? Well i guess if the motor is out, it will be easier to get to it.
for sure. you can see what going on better.
you dont want to pull it on a any angles really or the timing cover can break. keep it level and a little wiggle left and right while pulling it to the fender.
the motor or the elbow?
think about where the timing cover is then check back with me......:th_scratchhead:
I haven't gotten a chance to look to in depth at this engine yet. In fact I haven't seen it in the day light yet.
that cast elbow goes into the timing cover, if you dont pull the alt bracket off straight the timing cover cover coolant inlet hole will break. then your changing the timing cover on the engine.
this is why its just a little wiggle as you pull it off. this can seem like its taking forever, walk away, take 5, come back to it if need be.
once its off, clean the 3 holes out good and the cast elbow, take the new O ring off the new elbow your not using and put it on the cast elbow. re install it with a new upper elbow.
it has to come off in that case. its in the timing cover. and thats coming off to install a cam
thanks, wanna try and find an aluminum subframe for me?
thats your job pal. leg work, get to it lol
I assume this is just as easy for us supercharged folk, correct? Just a bit more finesse around the s/c is required?
same job....only your taking the sc belt off to get the other belt off.
what finesse? its not in the way at all.
Awesome, thanks for the info. Haven't really looked under the hood to check yet. Car is in for inspection and they called me and mentioned a coolant leak at one of the elbows. Also said it could take them 2hours because the supercharger. But they seem to be full of s***. Looks like well less than an hour to me. Will tell them to leave it be and I will fix it myself.
I will finally flush and switch to the green coolant while I am it. Get rid of that sloshing hopefully, too.
