Thread: How to change coolant elbows
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 93
  1. #21 Re: How to change coolant elbows
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    I usually put a THIN film or gray RTV around the o-ring on these. It helps keep them from leaking for sure and prevents the upper elbow from leaking. Never had any problems doing it this way and I have done at least 5-6 LIM jobs.
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  2. #22 Re: How to change coolant elbows
    I've done hundred or so... literally.
    never used rtv, never had a leak. I've had two start leaking after a year or more. ended up being the elbow heated and became a 45* angle instead of 90*
  3. #23 Re: How to change coolant elbows
    May 2011
    United States
    That's the problem I have usually seen, and RTV seems to have prevented it. If nothing else, the aluminium elbows will.
  4. #24 Re: How to change coolant elbows
    RTV can't prevent an elbow from warping. I've seen people use a little, a lot and still had problems. The biggest and best things I've found to work are in this thread.
    Clean the holes
    Lube the holes
    Ensure elbows don't have pressure on them
    using RTV just means when you swap the next elbow..you need to try and clean that extra crap out.
    Aluminum elbow isn't going to provide any better seal (same o-rings), it will..not become a 45* angle though.
  5. #25 Re: How to change coolant elbows
    GT Level Member 40th GP's Avatar
    Utah
    Hopefully this is an ok place to ask this, but does the tensioner bracket need to come up to change the power steering pump? Reason I ask is that I want to try and re-install the elbows, but I will probably be doing a power steering pump some time down the road. If this must come out I might as well do a little more planning and do them at the same time, but if that can be done with all this in place I will go ahead and attack the elbows now.
  6. #26 Re: How to change coolant elbows
    I suggested it that way the other day to someone. That's how I'd do it. I know the pump would be a pain to try and get out of the wheel well. If you pulled the tensioner bracket, then it would be a walk in the park.
  7. #27 Re: How to change coolant elbows
    Utah
    Probably worth a little more planning and doing it all at once. Thanks.
    May 2011
    United States
    I would pull the alt bracket while you are in there like billboost said. You can get the aluminum elbows from your local parts store, but you might want to order them sooner than later because they usually take a day or two to get in. Just add HP to the part number of the plastic elbows i think.
    Sent from my Droid
  9. #29 Re: How to change coolant elbows
    SE Level Member Bologna's Avatar
    Oct 2011
    Illinois
    Could you post some pictures? I can't find the bolts that are needed to take the alternator off.
  10. #30 Re: How to change coolant elbows
    GT Level Member beastin1's Avatar
    south elgin il.
    what holds the elbow in place? i have to change mine tomorrow, its spraying out coolent at about the bend and showering the tensioner pulley so the belt pops off..
    this is my first time switching one of these out so any tips or insight would be tremendously appreciated
    2002 Galaxy Silver 4dr. GTP...supercharger heaven.
    IM ON IT!!!!!!
  11. #31 Re: How to change coolant elbows
    SWPA
    Pressure and an o-ring. Read Bill's instructions. Its pretty straight forward.
  12. #32 Re: How to change coolant elbows
    south elgin il.
    ok, thats what i thought.. yes its a great write up, its hopefully gonna save my butt and get me to work monday... thanks alot
    IM ON IT!!!!!!
  13. #33 Re: How to change coolant elbows
    Quote Originally Posted by beastin1 View Post
    Please reread the first post. The pics of the alternator bracket, instructions that include socket size etc...I honestly don't know how to explain it easier. I'm pretty sure my 17 year old neighbor kid could swap these on her own.
  14. #34 Re: How to change coolant elbows
    Utah
    I am tearing into this now and have another question. Are all 4 ends and o-rings the same? In other words, does it matter which elbow goes in which location, and which end goes where? I am thinking they are all the same, but if there are any differences, perhaps that is where I went wrong.
  15. #35 Re: How to change coolant elbows
    the lower elbow has 2 different size ends, where the top one i believe is the same on both ends.
  16. #36 Re: How to change coolant elbows
    Donating Users JLiss's Avatar
    Dec 2012
    Aurora, IL
    subbed
  17. #37 Re: How to change coolant elbows
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    Are the engine holes supposed to have a stop ledge in them? because my 2000 Bonneville the holes feel completely smooth and have no stop ledge, they just go in and then drop off...?
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  18. #38 Re: How to change coolant elbows
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    Yep, u can litterally ibly put it in so far because its a 90.. If u tried to slide it in w out it being in the alt bracket, it would go all the way I
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  19. #39 Re: How to change coolant elbows
    Dec 2008
    Cedar Rapids, IA
    thank you
  20. #40 Re: How to change coolant elbows
    It's a 90...it can't go in past the bend.
    You guys may be taking the worlds easiest part to replace and making it seem way harder. Way way harder.
  1. Need to replace coolant elbows
    By Posty101 in forum Engine
    Last Post: 06-02-2011, 02:22 PM
  2. coolant elbows
    By noreasonwhyy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2010, 05:56 PM
  3. How do you replace the coolant elbows?
    By Mercenary in forum General Tech Discussion
    Last Post: 07-19-2010, 06:50 PM
  4. Coolant elbows
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 12-01-2009, 11:58 AM
  5. Coolant Elbows for 2000 GTP
    By nickbuol in forum General Tech Discussion
    Last Post: 07-21-2009, 10:51 PM
