Take steel wool and clean the holes where the elbows are located. Likely there's a ring of crud built up that's causing you to leak. Also check out Rockauto part number 47065HP, aluminum are available now.
Nice, those look sweet and you get both for less than I paid for one at the dealer. However I would be concerned that I would put those in and have the same problem again. When I did the LIM I had the manifold blasted and steamed at an engine shop and it was basically brand new when I put it back together. I can try the steel wool and clean the holes again, but I highly doubt there was anything in there that could be causing a problem since it was clean as can be when it went together and they leaked from the get-go. Any other ideas?
