Did you plug the temp sensor into an aeroforce, and it worked?
Plugged it right into the IAT harness. I was testing before running it to the aero. all you need for the aero is the proper info to enter.
Awesome right up!
Curious why you use pipe sealant instead of some kind of Loctite. Is the pipe sealant better in this application, or does it just not need anything stronger? Any downsides to using Loctite?
because the bolts go into the water jacket of the heads and the treads need to be sealed or they can seep coolant.
same goes for the 4 long water pump bolts, and a few timing cover bolts.
I use it because I want a sealing compound vs a harder to remove bolt compound.
You will find in the GM FSM's that they do call for blue loctite on the LIM bolts. My feel is that was the misconception of an engineer. I believe they felt the bolts were loosening up and causing the potential seepage/wicking of oil and coolant up the LIM bolt threads onto the top of the LIM.
In all the LIM jobs I've done, I have always used pipe sealant and never had a leak and no bolts have ever come loose or caused issues.
Bill, do you have a part # for that air temp sensor you put into the lim? Do you use that sensor and how so? Where did you plug it into the pcm?
Edit: never mind about the part #. I missed it in this thread. Still curious how this works with stock pcm. Guy tuning my car recommended I do this, but curious if it stays connected or is he just plunging it in to his scanner while tuning and after that it won't be used?
I had used the IAT and just drove gently.. later I hooked up to only the aeroforce to monitor it.
I'm doing LIM/UIM mod with L26 UIM. I want to block the coolant ports as I need the ZZP TB adapter plate, which blocks coolant to the TB, so I figure I might as well block it at the LIM and never worry about it again even with though I have the L26 top. However looking at my LIM, the coolant hole closest to thermostat is 5/64-3/32 thick, the other a bit more than 1/8. Relating that to 1/4 npt threads the first hole is a thick as center to center of 3 threads, so at best I may partially catch 2, the other about 3.5 threads C to C so that looks ok. Yours looks alot thicker. My LIM came out of an 03 NA. I'm a bit worried if the first hole will take the plug. Any ideas - thoughts? BillBoost37's pictures looked like his was /14-3/8, I say many threads, anyone else have a thin top like mine?
Also anyone looking for a counter sunk 1/4 npt plug, check your local ACE hardware, just got mine from there, all Ace's I've seen have a section with sliding bin doors filled with all types of npt fittings. I couldn't find these at the auto store and anyplace I did find online would take to long and cost way to much. At 1.99$ each visit your ACE. I am not an ACE employee ! Great place to get metric bolts as well to replace the security torx bolts on TB sensors.
Great tip on your grinding out the U turn coolant ports. I do not understand why those are even divided and require the u-turn fitting. Was this an option for coolant heater or alternate flow path for other engines ? As far as the gasket for this, it is included in the Felpro MS95812 UIM kit. Why it comes in that kit and not the LIM MS 98014T makes me wonder if someone was breathing to much exhaust one day at Felpro.
One more note, someone mentioned what material to use for the coolant plug and another pointed out "An engineer said they are dissimilar metals". Well I'm a nuclear engineer. Yes brass and aluminum are and by being dissimilar, the metal will migrate from one to the other, so it kind of gives it a self welding affect. OF course it more like a self crud like effect, (ever see brass and steel in old water pipes) especially if being thermally cycled, of course that's irrelevant if you are using sealant in there. But that's the basics behind dissimilar metals. No problem using the brass or a steel, it does have anti-corrosive Dex around it.
I would try the 1/8th npt tap, and when you are tapping down on the bigger hole, dont tap down very far. the tap is tapered, so the farther down you go, the deeper the plug will go when it tightens into the hole. I didn't measure the holes on the last one I did, but it was an L36 lower intake manifold. when I installed the plug in the hole, it wouldn't tightened down all the way and fell into the lim, so I used jb weld, and as far as I can tell, it sealed up. the other thing you can do is the dime mod. it's either a dime or a nickel that should fit into the recessed area of the hole, then just use jb weld to glue it in there. a lot of people have done it like that without problem.
I have a question regarding the IAT in the LIM. With that camaro/350 sensor did the PCM read the sensor faster? Looking at Torque it seems like the stock IAT is sooper slow to respond to temp change didn't know if that was a sensor thing or PCM thing regarding that. I also found this sensor labeled as a "Fast response" sensor here but didn't know if it would work the same as the Camaros and read accurately or if there were some some differences in resistance values so it would read off or something.
Bill had said in a earlier post it read fine with the camaro sensor. I was mostly curious if the refresh speed to display on a scanner was quicker or if there was another sensor that would work the same but be faster.
I have a question on the porting of the coolant passageway. With basic fluid dynamics and laminar flow in mind is it possible that removing the "restriction" would cause turbulent flow? Effectively not really increasing the cooling systems efficiency.
Maybe my ME mind set is over thinking it but seems like the cover acts as a turn to keep the fluid flowing with laminar flow.
Just a thought, anyone else have any input?
Cutting out that T just lets more coolant flow around that 180° turn.
I think it's already turbulent just from the fact that all of the coolant passages are rough cast. Lol
just finished this. taping was a lot of work without a tap handle. I used a 7/16" wrench.
Wondering if anyone had a pic of a slightly better angle of the finished end cap coolant passage? My eyes decieve me and want.to do it right. Thanks in advance
