Quote Originally Posted by Maximum Gnarnage View Post
Well i was thinking to vaccuum the coolant out of the port's after i drilled/tapped it to avoid this. Would that be suffifienct enough?
You realize its not much more work to pull the lim once you're this far in right? Yes you'll have to replace gaskets and clean things up but it would add an hour to the job and you'll be left knowing its done right instead of going hmm, wonder where that aluminum is rght about now.
