Thread: How to Mod a LIM
Results 1 to 20 of 105
  1. #1 Re: How to Mod a LIM
    Aug 2011
    colorado
    You can do it on the car if you don't mind aluminum chips in your coolant!
    Well i was thinking to vaccuum the coolant out of the port's after i drilled/tapped it to avoid this. Would that be suffifienct enough?
  2. #2 Re: How to Mod a LIM
    GT Level Member outonthetiles's Avatar
    Dec 2011
    Herkimer, NY
    You might be able to get away with it, but if it were my car, absolutely not.
  3. #3 Re: How to Mod a LIM
    Brownsburg
    Quote Originally Posted by Maximum Gnarnage View Post
    You realize its not much more work to pull the lim once you're this far in right? Yes you'll have to replace gaskets and clean things up but it would add an hour to the job and you'll be left knowing its done right instead of going hmm, wonder where that aluminum is rght about now.
lim, mod
