bill did you wire bruch or sand on the top? it looks like you did more than just powerwash
Plugs I used were brass, because Intrigue98 is an Engineer and said they should be dissimilar.
Temp sensor.. uh early 90's 5.7 motor. Toughest part is getting the threaded one. I looked on Rockauto and can't seem to find it quickly.
Tayl... some quench that with added fuel as well. Just on those cylinder though.
Taz.. cause it's in the How to section. Can't sticky everything. And on the top. If I used anything it was a 3m rotolok disc. I have the brown..which is what most mechanics use for all their work. Gotta go easy on aluminum and soft metals.
