Simple answer, tires are new and "I" installed them the week before installing the new CV shaft. That's when I found the inner boot had failed. Both discarded front tires had even wear, no issue with position of the steering wheel being off center and the car tracks straight rollin down the road.
I understand your intention is to help and your question is relavant, but if you read all my previous posts you would have read the vibration started AFTER installing a new CV shaft from Napa and only occurs under acceleration. No vibration when my foot is off the go pedal.... its smooth as silk then.
