Thread: General Info: Swap your steel oil pan for an aluminum one
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 69
BillBoost37 General Info: Swap your steel... 12-16-2010, 10:02 AM
Pure2sin Re: General Info: Swap your... 06-09-2013, 05:50 PM
BillBoost37 Re: General Info: Swap your... 06-10-2013, 06:05 AM
Pure2sin Re: General Info: Swap your... 06-10-2013, 08:09 PM
BillBoost37 Re: General Info: Swap your... 06-11-2013, 05:37 AM
Pure2sin Re: General Info: Swap your... 06-11-2013, 12:56 PM
slimguns Re: General Info: Swap your... 06-11-2013, 11:41 PM
Pure2sin Re: General Info: Swap your... 06-12-2013, 12:04 AM
Pure2sin Re: General Info: Swap your... 06-12-2013, 12:02 AM
BillBoost37 Re: General Info: Swap your... 06-12-2013, 06:01 AM
Pure2sin Re: General Info: Swap your... 06-12-2013, 01:28 PM
QUICKSILVER462 Re: General Info: Swap your... 06-12-2013, 02:06 PM
BillBoost37 Re: General Info: Swap your... 06-12-2013, 03:31 PM
Pure2sin Re: General Info: Swap your... 06-13-2013, 01:27 AM
BillBoost37 Re: General Info: Swap your... 06-13-2013, 06:03 AM
jlgp2007nc Re: General Info: Swap your... 06-13-2013, 06:10 AM
MGRead Re: General Info: Swap your... 11-18-2013, 12:20 PM
jlgp2007nc Re: General Info: Swap your... 11-18-2013, 12:41 PM
MGRead Re: General Info: Swap your... 11-19-2013, 08:58 PM
jlgp2007nc Re: General Info: Swap your... 11-19-2013, 09:26 PM
BillBoost37 Re: General Info: Swap your... 11-03-2014, 02:16 PM
HighOctaneRacing Re: General Info: Swap your... 03-13-2015, 11:07 AM
MGRead Re: General Info: Swap your... 11-19-2013, 11:12 PM
BillBoost37 Re: General Info: Swap your... 11-21-2013, 10:38 AM
MGRead Re: General Info: Swap your... 11-21-2013, 04:19 PM
MrDniceL36 Re: General Info: Swap your... 07-10-2014, 03:04 PM
aligater Re: General Info: Swap your... 11-03-2014, 08:59 PM
Turbocharged400sbc Re: General Info: Swap your... 11-08-2014, 09:49 AM
REGAL GUY Re: General Info: Swap your... 11-04-2014, 09:54 AM
BillBoost37 Re: General Info: Swap your... 11-04-2014, 09:57 AM
REGAL GUY Re: General Info: Swap your... 11-04-2014, 10:20 AM
BillBoost37 Re: General Info: Swap your... 11-04-2014, 10:22 AM
REGAL GUY Re: General Info: Swap your... 11-04-2014, 10:39 AM
BillBoost37 Re: General Info: Swap your... 11-04-2014, 10:45 AM
BillBoost37 Re: General Info: Swap your... 11-10-2014, 07:48 AM
Turbocharged400sbc Re: General Info: Swap your... 11-17-2014, 06:39 AM
Booba5185 Re: General Info: Swap your... 03-13-2015, 10:19 AM
BillBoost37 Re: General Info: Swap your... 03-13-2015, 10:26 AM
Booba5185 Re: General Info: Swap your... 03-13-2015, 10:28 AM
BillBoost37 Re: General Info: Swap your... 03-13-2015, 11:32 AM
Booba5185 Re: General Info: Swap your... 03-13-2015, 11:39 AM
BillBoost37 Re: General Info: Swap your... 03-13-2015, 12:05 PM
REDCRAPGP Re: General Info: Swap your... 03-18-2015, 11:48 PM
REGAL GUY Re: General Info: Swap your... 03-20-2015, 08:48 AM
BillBoost37 Re: General Info: Swap your... 03-20-2015, 10:30 AM
pushrod67 Re: General Info: Swap your... 10-25-2015, 08:34 PM
BillBoost37 Re: General Info: Swap your... 10-26-2015, 04:30 AM
Turbocharged400sbc Re: General Info: Swap your... 10-26-2015, 05:33 AM
pushrod67 Re: General Info: Swap your... 10-27-2015, 01:45 AM
chicagochuck Re: General Info: Swap your... 11-21-2015, 07:53 PM
pushrod67 Re: General Info: Swap your... 11-22-2015, 10:19 AM
chicagochuck Re: General Info: Swap your... 11-22-2015, 10:29 AM
CrazyGuy03 Re: General Info: Swap your... 11-22-2015, 12:00 PM
chicagochuck Re: General Info: Swap your... 11-22-2015, 01:31 PM
CrazyGuy03 Re: General Info: Swap your... 11-22-2015, 02:49 PM
CrazyGuy03 Re: General Info: Swap your... 11-22-2015, 02:54 PM
CrazyGuy03 Re: General Info: Swap your... 11-22-2015, 02:46 PM
chicagochuck Re: General Info: Swap your... 11-22-2015, 04:21 PM
Turbocharged400sbc Re: General Info: Swap your... 11-22-2015, 04:47 PM
chicagochuck Re: General Info: Swap your... 11-22-2015, 05:51 PM
CrazyGuy03 Re: General Info: Swap your... 11-22-2015, 06:21 PM
chicagochuck Re: General Info: Swap your... 11-22-2015, 06:59 PM
CrazyGuy03 Re: General Info: Swap your... 11-22-2015, 07:09 PM
chicagochuck Re: General Info: Swap your... 11-22-2015, 07:40 PM
Turbocharged400sbc Re: General Info: Swap your... 11-22-2015, 08:16 PM
chicagochuck Re: General Info: Swap your... 11-22-2015, 08:31 PM
Scottydoggs Re: General Info: Swap your... 11-22-2015, 08:34 PM
chicagochuck Re: General Info: Swap your... 11-22-2015, 10:12 PM
fomas Re: General Info: Swap your... 04-05-2022, 01:42 PM
  1. #1 General Info: Swap your steel oil pan for an aluminum one
    In the past I've swapped steel to aluminum oil pans on both H/C and W body cars. Recently I almost suggested to a W guy that he buy an H/C pan by mistake. The mount under the harmonic balancer on the W body prohibits this and vice versa on the H/C body.
    Here are the differences in picture form to help you guys make the right choices if you choose this "nice to have" mod. Ensure you have the proper oil pick up tube and oil filter adapter to go along with the oil pan of your choice. For example if swapping an H/C aluminum pan onto a 97 Bonneville you want all three items. In a Regal you need the pan and pick up tube only.
    W body pan with mount provision. W body with steel subframe requires the removal of the lip on the outter part of the mount bucket. It's a quick cut/grind.
    H body pan
  2. #2 Re: General Info: Swap your steel oil pan for an aluminum one
    Minnesota
    So if I do this swap into my 02 Monte Carlo that already has an aluminum sub frame, all I will need is the w-body pan and the pick-up tube? Do I still need the bracket as well?
  3. #3 Re: General Info: Swap your steel oil pan for an aluminum one
    If you don't have the bracket, you need the bracket.
  4. #4 Re: General Info: Swap your steel oil pan for an aluminum one
    Minnesota
    I got the bracket, pick-up tube and pan. All I am missing is the bolts for the bracket. Do you happen to have any extras Bill, or know the sizes?
  5. #5 Re: General Info: Swap your steel oil pan for an aluminum one
    I grabbed some out of the parts case the other day. They are gray/silver in color, and the same thread pitch/size as the bolts for the alt tension and dogbone mount, only about 1.5-2" in length. I think it's a M10 x 1.50 thread
  6. #6 Re: General Info: Swap your steel oil pan for an aluminum one
    Minnesota
    Thanks!
  7. #7 Re: General Info: Swap your steel oil pan for an aluminum one
    May 2012
    Albuquerque, NM
    What are the pros/cons (if any) of the aluminum pan? Cools oil better?
  8. #8 Re: General Info: Swap your steel oil pan for an aluminum one
    Minnesota
    Is this the right amount of gasket maker for these pans?
  9. #9 Re: General Info: Swap your steel oil pan for an aluminum one
    Minnesota
    Delete
  10. #10 Re: General Info: Swap your steel oil pan for an aluminum one
    As you noticed when you put it on, that's a bit much. That looks like copper RTV, in this case I would suggest the gray engine sealant like GM etc uses.
    When you put that much on, likely it gooped out all over the place.
  11. #11 Re: General Info: Swap your steel oil pan for an aluminum one
    Minnesota
    I got that picture off another forum. It looked like a little too much so I thought I would ask.
    I think I am going to use some Permatex Right Stuff on this. I have read and heard good things about it.
  12. #12 Re: General Info: Swap your steel oil pan for an aluminum one
    HUDSON
    WHen I did my pan, I used the GRAY silicon that is recommended for hard surfaces, and I only used a bead of about 1/4 the size of that in the picture, with a little extra where the front and rear covers sit on the rail.
  13. #13 Re: General Info: Swap your steel oil pan for an aluminum one
    The way I did it was to put some on the pan and smear it around with my finger. That way you ensure the entire surface is coated lightly and consistently. Right STuff should work well.
    Slim - it's structural and makes changing the mount and or pan gasket about a bazillion thousand gazillion times easier than that dumb horseshoe pile of crap bracket.
  14. #14 Re: General Info: Swap your steel oil pan for an aluminum one
    Minnesota
    Last questions...I think. lol
    Do you think I should get a new pick-up tube or should a used one be fine?
    Also is there a gasket for the pick-up tube? I can't seem to find any online.
  15. #15 Re: General Info: Swap your steel oil pan for an aluminum one
    A used one that is for that pan will be fine. It is different than the one for the steel pan. There is a gasket for it, however you can use a little RTV w/o worries. I've done it both ways.
  16. #16 Re: General Info: Swap your steel oil pan for an aluminum one
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Both ways indeed.
  17. #17 Re: General Info: Swap your steel oil pan for an aluminum one
    SE Level Member MGRead's Avatar
    Jun 2012
    Coral Spring, Fl
    Does anyone have any information on putting a aluminum pan on a 04 Grand Prix that has the aluminum sub farms. Everything I can find say I need the steel subfram
  18. #18 Re: General Info: Swap your steel oil pan for an aluminum one
    Sep 2012
    North Carolina
    You dont
    Sent from my SPH-L720 using Tapatalk
  19. #19 Re: General Info: Swap your steel oil pan for an aluminum one
    Jun 2012
    Coral Spring, Fl
    Quote Originally Posted by jlgp2007nc View Post
    You dont
    Why not?
  20. #20 Re: General Info: Swap your steel oil pan for an aluminum one
    Sep 2012
    North Carolina
    From what I understand, the aluminum pan and sub frame shouldn't have any issues. My 07 has both aluminum and came that way. I remember reading that modification of some bracket is needed for an aluminum pan and steel subframe.
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2024, 11:56 PM
  2. Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    By LowlyfeGTP in forum Visual/Body Modifications
    Last Post: 06-26-2012, 03:14 AM
  3. Top swap and general question
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2010, 08:28 PM
  4. Cradle steel vs. aluminum
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2009, 09:38 AM
  5. General Gen. V blower swap questions
    By GTPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2009, 06:38 PM
