Thread: How to: Remove an axle
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 120
  1. #81 Re: How to: Remove an axle
    May 2012
    Hubbardston, MA
    When replacing the axle or CV Joint, ensure that the spline is well seated. I thought it was seated. After finishing the job I test drove it. Everything was cool until I floored it, the spline separated and I had to redo the whole job.
    I ended up removing everything and started over at the assembly stage. Once the spline was positioned properly, I placed the wooden handle of my sledge hammer on the rubber covered end and struck it several times until it was well seated. I used caution not to damage the rubber cover. Reassembled everything, and it worked great.
  2. #82 Re: How to: Remove an axle
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    Working on my passenger side now. Ball joint free, can't get the outside part of the axle free from the wheel bearing area. Even removed caliper and rotor and wheel bearing (think it's bad too) I'd really prefer not to disconnect the strut but that looks like my only option.
    Also, how freely should the bearing turn. There isnt any noise when I turn this one but it doesn't move freely either.
    Thanks!!!
  3. #83 Re: How to: Remove an axle
    Just swing the whole knuckle to the side, the axle will slip out.
  4. #84 Re: How to: Remove an axle
    Toledo, Ohio
    Doesn't matter which way I turn it I can't get it out.
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  5. #85 Re: How to: Remove an axle
    You must pop the lower ball joint out of the knuckle, that is the only way to get the knucke to move forward and towards the passenger side of the car.
    Swing it up and over and the axle will slide out with some love.
  6. #86 Re: How to: Remove an axle
    Toledo, Ohio
    Must be missing something, started on the drivers side. Ball joint is popped free. Turning the hub pulling the caliper towards me with one hand and trying to pull the axle free with the other.....and no go. The control arm turns as far as the sway bar connection. How to said to loosen it, does it need to be removed to turn the control arm further? Thanks!!!!
  7. #87 Re: How to: Remove an axle
    Toledo, Ohio
    I can get the axle about 3/4 of the way out of the bearing.
  8. #88 Re: How to: Remove an axle
    Toledo, Ohio
    Think I found my problem, have the upper ball joint free....and not lower.....dah.
  9. #89 Re: How to: Remove an axle
    There is no upper ball joint...
    I did one on the garage floor is maybe 30min total, pop the lower free and the axle will come out when the knuckle is moved to the side.
  10. #90 Re: How to: Remove an axle
    Toledo, Ohio
    Sorry, I meant tie rod. I didn't even see the castle nut just under the end of the axle.
  11. #91 Re: How to: Remove an axle
    I never remove the tie rod. Not sure what piece you might be missing or misinterpreting...but this should be a quick easy.
    If you can, snap a picture. Might help us understand better
  12. #92 Re: How to: Remove an axle
    Toledo, Ohio
    Thanks! Pic in post #84
  13. #93 Re: How to: Remove an axle
    Toledo, Ohio
    Ok, have that 18mm off but can't lift the strut or lower the control arm to separate
  14. #94 Re: How to: Remove an axle
    with the tie rod popped off the knuckle i turn the knuckle and push the axle in and bend it and slide it past the hole in the knuckle.
    then you can start the fun part of popping it out of the tranny. why is the hub off? unless your changing it theres no reason to remove it.
  15. #95 Re: How to: Remove an axle
    Toledo, Ohio
    Getting the passenger axle out was a piece of cake. Had to remove the 2 strut bolts though.
    Drivers side.....went straight to the strut bolts. Just holding the axle it came apart in my hands. This is all that's left.
  16. #96 Re: How to: Remove an axle
    Toledo, Ohio
    Great, outer shell came free but this is still in the transmission.
  17. #97 Re: How to: Remove an axle
    Toledo, Ohio
    Can't punch from the passenger side.
  18. #98 Re: How to: Remove an axle
    You'll need an alignment now.
  19. #99 Re: How to: Remove an axle
    Toledo, Ohio
    That's ok, still have to figure out how to get the piece out. Gave up for today.
    Thanks for all of the help!!!
  20. #100 Re: How to: Remove an axle
    That thing inside the transmission on the drivers side is suppose to be there.
    All you had to do was look at the different ends of each axle, they are suppose to be different.
    One has a shaft end because that enters the diff inside the tranny, the other is like a female end because the shaft inside the trans will connect to that part.
  1. Possible Bad CV Axle?
    By mlasnoski in forum Brakes/Suspension/Chassis
    Last Post: 10-11-2011, 02:47 PM
  2. Is my axle going out?
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-26-2010, 07:05 AM
  3. axle
    By tylersgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-01-2010, 07:35 PM
  4. Grr. Axle Nut Size?
    By Gregorius in forum Brakes/Suspension/Chassis
    Last Post: 09-18-2009, 06:35 PM
  5. CV Axle
    By stlmo_gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2008, 01:24 PM
