Thread: Simple Intake (pictures)
Page 17 of 23 FirstFirst ... 71516171819 ... LastLast
Results 321 to 340 of 454
  1. #321 Re: Simple Intake (pictures)
    i used gorilla glue to set the sensor in.
  2. #322 Re: Simple Intake (pictures)
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    I would like to retain the ability to remove it in one piece.
    Sent from my Galaxy Nexus using Tapatalk 2
  3. #323 Re: Simple Intake (pictures)
    Silicon?
    04 Comp G.
  4. #324 Re: Simple Intake (pictures)
    Arizona
    You could put it in the rubber coupler portion cut a a small x and press the iat in.
  5. #325 Re: Simple Intake (pictures)
    Mar 2013
    Manitoba, Canada
    I think I trust the grommet idea a bit more. probably go with that.
  6. #326 Re: Simple Intake (pictures)
    I live here. DirtDog's Avatar
    Jun 2012
    U guys are over thinking CAI's & HAI's
  7. #327 Re: Simple Intake (pictures)
    ive had mine out since, re glued it back in. gorilla glue will break free, with easy really. you only use a small amount.
  8. #328 Re: Simple Intake (pictures)
    SE Level Member ItsMeDc's Avatar
    Aug 2013
    Michigan
    Anybody who painted theirs with the night temp paint use primer? Any problems with the paint flaking off or not sticking well?
  9. #329 Re: Simple Intake (pictures)
    straight rustolium. i did sand the pvc with 100 grit sand paper and took a knife to the mold seams to smooth the outside of the pvc.
    then hung it with a string and a pencil, then sprayed it with many light coats waiting 10 minutes in between coats. first coat was nothing more then a dusting, more of a tack coat.
  10. #330 Re: Simple Intake (pictures)
  11. #331 Re: Simple Intake (pictures)
    Aug 2013
    Michigan
    Thanks a bunch! I plan on taking a knife and trying to smooth it out as well. Picked up some Rustolium high heat ultra.
  12. #332 Re: Simple Intake (pictures)
    Donating Users onetyme77's Avatar
    texas
    Has any one else been having trouble with there intakes staying on the pvc? I have tighten and tighten and tighten the crap out of the clamp, I have even changed the clamp, but it always manages to come off. Any solutions out there?
    Sent from my SCH-I535 using Tapatalk 2
  13. #333 Re: Simple Intake (pictures)
    mine fell off a few times, then it just stopped falling off. im still using the crappy clamps that came with the coupler too. seems like it need a bunch of heat cycles till it stay put.
  14. #334 Re: Simple Intake (pictures)
    texas
    It's been like a year and it still wiggles off! I'm so fed up with it I'm putting the stock setup back in. Plus ever since I put the open filter on my car sounds like a 4x4 when it slows down, u know that roaring sound 4x4 tires make?
  15. #335 Re: Simple Intake (pictures)
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Quote Originally Posted by onetyme77 View Post
    But you know that whine the blower makes with the open cone? Blower whine > Sounding like a 4x4
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  16. #336 Re: Simple Intake (pictures)
    is your car n/a? cause i dont have that sound. you get new tires or something since the intake?
  17. #337 Re: Simple Intake (pictures)
    texas
    No its not super charged, and honestly, Idk if I got my tires before or after I did my intake. At first I thought was my brakes, but I don't have to hit my brakes to hear it, and it's only at very low speeds or when I'm slowing down.
  18. #338 Re: Simple Intake (pictures)
    GTP Level Member tms8582's Avatar
    Washington Michigan
    I have an idea.... Buy a real intake and it won't fall off.... Imagine that!
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  19. #339 Re: Simple Intake (pictures)
    texas
    Quote Originally Posted by tms8582 View Post
    Take ur smart comments to another forum, we are here to help each other not give each other a hard time
  20. #340 Re: Simple Intake (pictures)
    Aug 2012
    Calm yourself. He's just messing with you. All love on this site. Not really. That's a lie lol
  1. simple trick.
    Last Post: 06-09-2013, 02:26 PM
  2. So simple yet A PITA
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 03-30-2010, 11:21 PM
  3. simple or not so simple
    By Ironwarrior in forum Canada
    Last Post: 07-04-2009, 06:00 PM
  4. fenderwell intake pictures
    By deft in forum 5.3L V8 (LS4)
    Last Post: 01-11-2008, 11:17 AM
