Thread: Wiring an Aeroforce Interceptor Scangauge
Results 1 to 20 of 42
  1. #1 Re: Wiring an Aeroforce Interceptor Scangauge
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    I plugged mine directly in the OBD2 with the jumper on and i had to manually turn it on and it would turn off when i turned the car off but it wouldnt turn on again if i started the car (the annunciators flash)
    I tried running the power wire to the PGM fuse (kept the jumper on with the wire wrapped arround the 2 connectors) and as soon as i plugged my OBD2 my A pillar gauges and my radio would turn on without even having the key in the ignition...
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  1. Aeroforce Interceptor-where to purchase?
    By Liquifire in forum General Tech Discussion
    Last Post: 07-16-2009, 12:30 AM
  2. scangauge II vs. aeroforce interceptor
    By kyle99gtp in forum General Tech Discussion
    Last Post: 06-25-2008, 09:48 PM
