Thread: How to Braided fuel lines
Results 1 to 9 of 9
Threaded View
BillBoost37 How to Braided fuel lines 01-24-2011, 01:23 PM
foursixer Re: How to Braided fuel lines 01-24-2011, 02:25 PM
BillBoost37 Re: How to Braided fuel lines 01-24-2011, 02:51 PM
matt5112 Re: How to Braided fuel lines 01-25-2011, 11:10 AM
BillBoost37 Re: How to Braided fuel lines 01-25-2011, 11:13 AM
Z34Phoenix Re: How to Braided fuel lines 09-01-2012, 09:52 PM
Dallasneon Everything on your list is... 09-01-2012, 11:41 PM
Pure2sin Re: How to Braided fuel lines 09-02-2012, 03:10 AM
Beelzeboul Re: How to Braided fuel lines 09-11-2012, 03:20 PM
  1. #1 How to Braided fuel lines
    There are some different fittings etc when talking about braided fuel lines. This post is a basic how to and was done on a Bonneville. The steps are basdically the same though.
    Got most of the parts from Summit. they seemed to have the best prices.
    To go from hard metal lines to fuel rails.
    (Call your local Swagelok dealer for these two parts)
    Swagelok for the 5/16" tube adapter to -6AN is part # SS-500-6-6AN
    Swagelok for the 3/8" tube adapter to -6AN is part # SS-600-6-6AN
    Russel RUS-640850 Fuel rail fitting
    Russel RUS-640860 Fuel rail fitting
    EAR-981506ERL Fitting, Coupler, Straight, Male -6 AN to Male -6 AN, Aluminum, Blue, Each 2 $5.90
    SUM-220687 Fitting, Hose End, 90 Degree, -6 AN Hose to Female -6 AN, Aluminum, Red/Blue Anodized, Each 2 $25.90
    SUM-220690 Fitting, Hose End, Straight, -6 AN Hose to Female -6 AN, Aluminum, Red/Blue Anodized, Each 2 $9.76
    SUM-230610 Hose, Braided Stainless Steel, -6 AN, 10 ft. Length, Each 1 $36.95
    Keep in mind that this is on a Bonneville and the Swageloks were not used in the below pictures.
    If you want to run the lines all the way back to the filter and nylon return these are the fittings you need:
    Fuel Filter and Return Line Fittings:
    Fuel Filter (16mm x 1.5) to -6 AN
    -6 AN to 5/16 in. Female Spring Lock[/
    I should have looked under my hood a little more and then I would have ordered one fitting differently. A straight piece instead of a bend for the supply line. Then the regulator would clear the line to the rail for supply. Either way.. it's fairly easy to do and looks amazing.
    From this
    To this
    A couple hose connections
    Cut a line or two
    In the 96-99 B'ville the lines run back to the firewall, to the passenger side behind the strut (no f'n room there) and that is where they convert to metal lines. Unclipping a line holder at the back and lower area of the engine bay I was able to get enough movement to gently pull the lines out from behind the strut one at a time. This gave me enough room to cut the old plastic off, attached the tube to AN fittings and hook them to the braided line which I ran along the firewall before connecting to the new fittings. Pushed the line back in and pulled the excess SS line back toward the rails. Made the rail connections and hoped for the best when I pressurized it the first time.
    No leaks and pressure is right where it was before. Only difference is no nylon lines to possibly kink.
    On a W body, it's relatively easy to get at the lines near the master cylinder. On go the swagelocks, a couple female hose ends with the hose already attached, then run the hose to the fuel rail. At this point Connect another end on and put the Russell/Earl fuel rail clip piece on and you are all set.
  1. steel braided brake lines
    By Wadeb79 in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2008, 10:15 PM
  2. SS fuel Lines
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2008, 01:02 AM
