Thread: scangauge II vs. aeroforce interceptor
Results 1 to 20 of 33
kyle99gtp scangauge II vs. aeroforce... 06-18-2008, 01:29 PM
VinnieGTP Re: scangauge II vs.... 06-18-2008, 02:05 PM
Reptile Re: scangauge II vs.... 06-18-2008, 02:14 PM
kyle99gtp Re: scangauge II vs.... 06-18-2008, 02:24 PM
FoSHO99 Re: scangauge II vs.... 06-18-2008, 04:28 PM
Sabrewings Re: scangauge II vs.... 06-18-2008, 06:53 PM
IndeedSS Re: scangauge II vs.... 06-18-2008, 07:13 PM
VinnieGTP Re: scangauge II vs.... 06-18-2008, 08:48 PM
kyle99gtp Re: scangauge II vs.... 06-19-2008, 12:54 AM
SyntheticShield Re: scangauge II vs.... 06-19-2008, 10:57 AM
Sabrewings Re: scangauge II vs.... 06-19-2008, 07:30 PM
archemedes Re: scangauge II vs.... 06-19-2008, 10:29 PM
Sabrewings Re: scangauge II vs.... 06-19-2008, 10:53 PM
kyle99gtp Re: scangauge II vs.... 06-19-2008, 12:50 PM
VinnieGTP Re: scangauge II vs.... 06-19-2008, 08:11 PM
kyle99gtp Re: scangauge II vs.... 06-20-2008, 02:21 PM
IndeedSS Re: scangauge II vs.... 06-21-2008, 07:36 AM
VinnieGTP Re: scangauge II vs.... 06-20-2008, 11:31 PM
VinnieGTP Re: scangauge II vs.... 06-21-2008, 10:26 AM
kyle99gtp Re: scangauge II vs.... 06-21-2008, 11:51 PM
IndeedSS Re: scangauge II vs.... 06-22-2008, 07:26 AM
kyle99gtp Re: scangauge II vs.... 06-23-2008, 12:09 AM
blowfishRus6 Re: scangauge II vs.... 06-25-2008, 12:10 PM
Sabrewings Re: scangauge II vs.... 06-25-2008, 07:40 PM
blowfishRus6 Re: scangauge II vs.... 06-25-2008, 09:48 PM
  1. #1 scangauge II vs. aeroforce interceptor
    NE Ohio
    i want a guage that can read and clear codes and monitor KR. both the scanguage and the interceptor can do these things.
    i have a 3 gauge a-pillar pod that i want to fill up. i have an aem wideband for one spot. my other options would be to get a dual aeroforce setup to take up the other two holes, or to get a scanguage II, mount it on the steering wheel, and get an oil pressure and a fuel pressure guage. if i get either, im goign to have to buy sending units for soem of the stuff anyhow (oil press, fuel press).
    the interceptor has a lot more parameters, but for the dual setup im looking at $400+. i can pick up a scanguageII on ebay for 160 shipped..the aeroforce will also flash at me if any parameters i set drop or increase too much (oil pressure and KR, mainly)
    what i want to see most in a gauge is a display of
    - oil pressure
    - fuel pressure
    - boost
    - KR
    - IAT
    - voltage
    - ablitly to read/clear DTC's
    the scanguage cannot give me oil or fuel pressure, which is why if i got it id have to get separate gauges for that.
    so really its ~ $400 for the dual aeroforce, plus more for sending units
    or
    $160 for the scanguage II, plus ~ $100 for an eletrical oil pressure gauge and ~ $200 for an elctrical fuel pressure gauge
    either way, im looking at about $500 when its all said and done.
    can anyone shine some light on this for me?
  2. #2 Re: scangauge II vs. aeroforce interceptor
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Scan Gauge doesn't scan most peremeters. Korey on GOClub just bought one and it won't even read KR.
    Are you doing a wideband?
    I decided to get the Interceptor, Innovate LC-1 wideband and the oil pressure sender accessory for the interceptor. Then a rail mounted fuel pressure gauge and a boost gauge. Thats 2 gauges in a HUD pod so there arent a ton of gauges to take your eyes off the road. If you're watching a WB I don't see why you need to look at FP also. If there is a fuel issue the WB will show it. The FP gauge is more for troubleshooting and can be put on a braided hose and taped to the windshield like Merc does if you need to watch it while driving.
    Less is more IMO when it takes your eyes off the road. Im my setup I can watch 3 parameters from 2 gauges and they are right next to the HUD.
  3. #3 Re: scangauge II vs. aeroforce interceptor
    Bastard Reptile's Avatar
    Kansas City, MO
    Another vote here for the interceptor gauges. Probably one of the best investments I've made for the car, and Pat's customer service is top notch. They are well worth the money, and they actually fit someplace compared to the shape of the scangauge.
  4. #4 Re: scangauge II vs. aeroforce interceptor
    NE Ohio
    yeah, i have an aem uego wideband, i just need to install it. i literally have everythign ready to go except i havent gotten the bung welded in to my downpipe yet.
  5. #5 Re: scangauge II vs. aeroforce interceptor
    Jan 1970
    Maquoketa, Iowa
    Aeroforce guage by far.
  6. #6 Re: scangauge II vs. aeroforce interceptor
    Barksdale AFB, LA
    Aeroforce only reads oil pressure properly on GM V8s. It gives some crazy reading on the 3800. Doesn't do fuel pressure either (but does have analog inputs). Get a single Aeroforce and your oil pressure gauge. Done.
    2009 Subaru Impreza WRX STI
  7. #7 Re: scangauge II vs. aeroforce interceptor
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I don't know if this is the latest model, but Aeroforce thread CGP This concerns me as I've been waiting almost two weeks for one.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  8. #8 Re: scangauge II vs. aeroforce interceptor
    Las Cruces, NM
    Quote Originally Posted by Sabrewings View Post
    Please tell me more as mine arent hooked up yet.
  9. #9 Re: scangauge II vs. aeroforce interceptor
    Barksdale AFB, LA
    What more is there? The oil pressure gives you some crazy 6k+ PSI reading. They say on their site the oil pressure value is only for some GM V8 vehicles. And it doesn't read fuel pressure.
    Since you got the oil pressure sender accessory, yours should work. But it can't use the stock oil pressure sender over the OBD2 bus. Not sure why since my stock oil pressure gauge works just fine.
  10. #10 Re: scangauge II vs. aeroforce interceptor
    NE Ohio
    yeah, i know id need to buy sending units, im cool with that. im just trying to decide which 500 bucks to spend..
  11. #11 Re: scangauge II vs. aeroforce interceptor
    Oklahoma
    The Bonneville's have an oil pressure sensor that goes to the dash. Could this be used as well or is that the one Vinnie is referring to?
  12. #12 Re: scangauge II vs. aeroforce interceptor
    Barksdale AFB, LA
    That's the same one already on your car. The PCM is monitoring it, it's just that for some reason Pontiac didn't feel the GP needed a gauge.
  13. #13 Re: scangauge II vs. aeroforce interceptor
    Saraland Alabama
    but the upscale bonneville (where the driver may look at the speedo if your lucky) does
  14. #14 Re: scangauge II vs. aeroforce interceptor
    Barksdale AFB, LA
    Quote Originally Posted by archemedes View Post
    I know, that's why I said the GP, not just Pontiacs in general. I did used to work for a Pontiac dealer.
  15. #15 Re: scangauge II vs. aeroforce interceptor
    NE Ohio
    it might work, but aeroforce sells a sending unit to correctly read oil pressure on a non v8 car
  16. #16 Re: scangauge II vs. aeroforce interceptor
    Las Cruces, NM
    Yeah, I posted the info on the kit they use above. Its just from an 05 Vette.
  17. #17 Re: scangauge II vs. aeroforce interceptor
    NE Ohio
    im getting the dual interceptor setup. vinnie, greg is hooking me up.
  18. #18 Re: scangauge II vs. aeroforce interceptor
    St Louis MO
    Quote Originally Posted by kyle99gtp View Post
    Greg from Pace?
    2010 Camaro SS LS3
  19. #19 Re: scangauge II vs. aeroforce interceptor
    Las Cruces, NM
    I knew he would, that's how I got mine
  20. #20 Re: scangauge II vs. aeroforce interceptor
    Las Cruces, NM
    Yes
  1. Scangauge 2 first impression
    By the1euge in forum Off Topic Discussion
    Last Post: 04-20-2008, 07:15 AM
  2. Has anybody ever used a "Scangauge II"?
    By Grumbletron 4000 in forum Off Topic Discussion
    Last Post: 01-04-2008, 01:22 PM
