Thread: Blend Door Actuator Replacement
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 90
  1. #41 Re: Blend Door Actuator Replacement
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    well i took one apart being stupid, and moved that position sensor gear. so its not where it was originally. thats why i need to know where it is positioned
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #42 Re: Blend Door Actuator Replacement
    got ya. not sure if i have a bad one in my trunk still, if i do ill pop it open and take a pic for ya tomorrow.
  3. #43 Re: Blend Door Actuator Replacement
    Mar 2012
    Dallas
    thanks!
  4. #44 Re: Blend Door Actuator Replacement
    Mar 2012
    Dallas
    im done messing with this damn thing. finally pulled the actuators off and rigged it on cold. gonna have to rig the mode doors too. going to plug the SC tree and move the mode door to face only. and stick it there.
    FYI that 20a HVAC Control fuse dont do ****. i taqke it out and the HVAC module stays on. i hate the guy who had my car before me. there is no telling what this guy did to the AC system.
    on another **** note, my car gets hot with the AC on. normally sits at 185* now gets up to 210-220*
    dragging compressor??
  5. #45 Re: Blend Door Actuator Replacement
    sh it, i forgot to get that pic for ya. i got stuck working in the heat for a few days. never even looked for it lol sorry.
    my car runs cooler with the a/c on as both fans are on. so when the ac is turned on, both fans come on full time?
    i went over a year or so with no actuators, the driver side would walk back on its own, so i set the knob to cold, and made the actuator match, then just laid it on the knob, no screws at all, it held it in place.
    this was also good for winter time, as full hot is no good but a touch over 1/2 way worked fine for me, once again the actuator held the knob in position.
  6. #46 Re: Blend Door Actuator Replacement
    Mar 2012
    Dallas
    yup both fans are blowing full speed.
  7. #47 Re: Blend Door Actuator Replacement
    GT Level Member 02GPinNY's Avatar
    Aug 2012
    Port Chester, NY
    Right now I'm having an issue with my 02' GP GT. The passenger side blows cold air on AC but the driver's side blows hot. Does anyone know the part number for that Actuator Motor. I'm assuming it needs to be replaced. Thanks. I'm tired of driving with the driver's side vents shut and turning all the passenger side vents my direction. It's getting too hot these days for that kind of nonsense. I'd rather sweat my azz off for one day repairing it.
    2002 GT Red, Stock, Work In Progress..........
  8. #48 Re: Blend Door Actuator Replacement
    Mar 2012
    Dallas
    automatic AC or manual? auto is 604-106 manual is 604-107
  9. #49 Re: Blend Door Actuator Replacement
    Aug 2012
    Port Chester, NY
    Not to sound dumb, but I am. How do I tell if it's an Auto System or a Manual one??
  10. #50 Re: Blend Door Actuator Replacement
    Jun 2011
    N. Ga Mtns
    Quote Originally Posted by 02GPinNY View Post
    I had the exact same symptoms on my '03 GT, turns out it was the refrigerant level was low, not the actuators. Worth a check, it's an easy fix if that's the problem.
    If you need an actuator, RockAuto has the best price by far.
    Good luck!
  11. #51 Re: Blend Door Actuator Replacement
    Aug 2012
    Port Chester, NY
    Quote Originally Posted by GT03 View Post
    Good luck!
    Thanks! I actually have a recharge system in the trunk right now. I'll dump it in when I get home to see what happens. I will say that the passenger side doesn't blow as cold as my 86' Olds did so you may be right. I still don't know how to differentiate between Auto AC and Manual AC systems??
  12. #52 Re: Blend Door Actuator Replacement
    you can pop the d/s actuator off and then turn the knob by hand, if you can make it blow cold manually the actuator is bad.
    if its still warm, the system is low for sure. but you got the a/c gauges so you can also test the line pressures.
    and its been f ing hot here the last few days.
    not sure what the difference its either, you got lkq parts right down the road from you, go ask them for a used one. LKQ Hunts Point Auto Parts
  13. #53 Re: Blend Door Actuator Replacement
    Aug 2012
    Port Chester, NY
    Thanks Scotty! I'm so glad my work station is directly across from the AC Unit here at the lumber yard. I'll install the freon first and if it's still hot I'll try and manually close the door. I saw only one video from a 98' Chevy Something, and it didn't look so bad to reach from under the driver's side dash.
  14. #54 Re: Blend Door Actuator Replacement
    first post of this thread is the how too to change them. drivers side is a bit tight. but very doable. i wear size 3 x gloves, so i got large hands, yes i bled a little, but i got em in and out. more then once sadly lol
  15. #55 Re: Blend Door Actuator Replacement
    Aug 2012
    Port Chester, NY
    Well, thanks Scotty. I dodged a bullet with this one. I got home from work and attached the can of AC Pro, set the AC to Max, and let her rip. It was definitely low of juice. After 5 minutes the can was empty and all the vents were now blowing COLD ICY AIR!!! Whew! No taking apart the dash for me thank God! Also, I noticed as you had said, my temp gauge went down with the AC on Max too. Thanks everyone for all the help. No more sweating for me in the GP!
  16. #56 Re: Blend Door Actuator Replacement
    Aug 2012
    Port Chester, NY
    I guess I spoke too soon! I get downstairs this morning and hit the AC Control and the passenger side is ice cold but the driver's is still running warmer. Big difference though from before, just not as cold as the other side. So I guess I'll be under the dash this weekend!
  17. #57 Re: Blend Door Actuator Replacement
    Jun 2011
    N. Ga Mtns
    Was it up to the proper charge pressure for the ambient temp? When I got mine to spec, the drivers side ended up slightly cooler than the passenger side, go figure...
    From Msg #18 "UPDATE 2: Refrigerant was low, recharged, now the with the same parameters as above I have 38º from drivers center outlet and 40º from the passenger center outlet. Why the drivers side is now cooler than the passenger side is a mystery. I'm just happy it's cold air that's coming out for cheap! Two 12 oz cans did it.
    So what seemed to be a blend door problem, wasn't."
  18. #58 Re: Blend Door Actuator Replacement
    Aug 2012
    Port Chester, NY
    Yep, I set the ambient temp gauge and it was at the proper charge, but at the "low end" of the spectrum. The can was empty at that point. At the instant I finished, both sides were blowing cold with the passenger side just a smidgen colder. I never sat for an extended period of time though. I just shut it off and went upstairs. I may need another can to get to the higher end of the scale.
  19. #59 Re: Blend Door Actuator Replacement
    i think it has a leak somewhere. if it worked, now dont work, it leaked out.
  20. #60 Re: Blend Door Actuator Replacement
    Jun 2011
    N. Ga Mtns
    Yep, since mine was low, I added a refrigerant that contained a stop-leak. Still working OK after ~year.
  1. Blend door
    By BADAZGTP in forum General Tech Discussion
    Last Post: 06-27-2016, 02:25 AM
  2. Blend Door
    By 98GTPON22s in forum General Tech Discussion
    Last Post: 03-07-2012, 09:50 PM
  3. Temperature Actuator
    By s7falcon in forum Shops and Community Heroes
    Last Post: 09-04-2009, 11:36 AM
  4. 97 grand prix gt 3.8 liter ac blend door actuator
    By king1997 in forum General Tech Discussion
    Last Post: 06-18-2009, 07:58 PM
  5. Throttle Actuator
    By chrisothoulos in forum General Tech Discussion
    Last Post: 05-22-2009, 03:56 PM
