Could you please post instructions for a single climate control system?
Both Heater core hoses are hot, so I assume this is the problem. When temp is set to hot, flow is low and lukewarm, when I switch temperature setting to cold, flow increases and turns cold. Does this seem like a Blend Door Actuator problem?
Thank you.
