Thread: DIY: Plastic gas tank upgrade
Results 1 to 20 of 26
OH4CompG DIY: Plastic gas tank upgrade 03-04-2012, 08:38 PM
jaybaum96 Re: DIY: Plastic gas tank... 03-04-2012, 09:09 PM
limegreen Re: DIY: Plastic gas tank... 03-04-2012, 09:19 PM
OH4CompG Re: DIY: Plastic gas tank... 03-04-2012, 10:35 PM
BillBoost37 Re: DIY: Plastic gas tank... 03-05-2012, 06:56 AM
OH4CompG Re: DIY: Plastic gas tank... 03-05-2012, 12:27 PM
BillBoost37 Re: DIY: Plastic gas tank... 03-05-2012, 12:40 PM
Logan541 Re: DIY: Plastic gas tank... 03-05-2012, 04:03 PM
coolone Re: DIY: Plastic gas tank... 05-28-2012, 10:17 AM
Logan541 Re: DIY: Plastic gas tank... 03-05-2012, 03:43 PM
OH4CompG Re: DIY: Plastic gas tank... 03-05-2012, 04:39 PM
Logan541 Re: DIY: Plastic gas tank... 03-05-2012, 06:05 PM
BillBoost37 Re: DIY: Plastic gas tank... 03-06-2012, 08:14 AM
tc300 Re: DIY: Plastic gas tank... 03-15-2012, 05:18 AM
Erics00LS Uh.. always thought mine was... 05-28-2012, 05:59 AM
gtpeddie Re: DIY: Plastic gas tank... 05-28-2012, 11:58 PM
Logan541 Re: DIY: Plastic gas tank... 05-29-2012, 12:53 PM
grandprixgtx Re: DIY: Plastic gas tank... 06-02-2013, 01:07 AM
OH4CompG Re: DIY: Plastic gas tank... 06-03-2013, 07:36 PM
Booba5185 Re: DIY: Plastic gas tank... 06-03-2013, 10:57 PM
OH4CompG Re: DIY: Plastic gas tank... 06-04-2013, 12:10 AM
Booba5185 Re: DIY: Plastic gas tank... 06-04-2013, 12:26 AM
  1. #1 DIY: Plastic gas tank upgrade
    Portland Oregon
    Ok, since I searched and searched and searched before I did this to find out if anyone has done it and only found answers like "it should work" I figured I'd do a DIY for everyone that wants to do this.
    Things you'll need....
    1. Plastic tank complete with pump and plastic fuel lines all down to the fuel filter and steel fittings, and the 5/8ths vent hose from the charcoal canister on the new tank
    2. Filler neck and fill hose from the car that the tank came from.
    3. Fuel tank straps from the car with the plastic tank.
    4. 5/8ths double sided barbed fitting
    Tools needed...
    15mm swivel socket and a long extension and socket wrench 3/8ths drive.
    5/16ths socket or flat screwdriver for hose clamps
    10mm socket with short extension
    Phillips screwdriver
    Floor jack, chocks, and jack stands
    1. First step is to make sure you have a nearly empty tank or pump all the fuel out into a gas can. This is up to you on how you do it. I used a fuel pressure gauge attached to the fuel rail with a drain hose on the other end of the gauge while jumping the fuel pump relay to pump the tank dry.
    2. Jack the car up by the rear subframe and put jack stands on the rear unibody frame rails to hold the car up.
    3. Disconnect the fuel lines at the filter and drain any remaining fuel into a small drain pan. These are clip together quick disconnect lines. I find a pick or small flat blade screwdriver may help you get these off.
    4. Remove the access panel in the trunk by removing the 10mm speed nuts and disconnect the electrical connectors and the fuel lines at the pump.
    5. Pull the left rear tire and the rear wheel well splash guard by removing the 2x10mm speed nuts and two Phillips head screws exposing the charcoal canister and vent solenoid. remove the 10mm screw from the canister bracket and you can remove the canister. Make sure you unplug the vent solenoid electrical connector and remove the quick disconnect vent line. You'll need the 5/8ths vent hose attached to the solenoid and the canister so remove it from the canister and set aside. The plastic tank has the charcoal canister attached to the tank. You'll use the new one.
    6. Time to get under the car and disconnect any and all quick connect lines that you can see. There are a bunch, it's pretty ridiculous.
    7. Using a long flat blade screwdriver or the 5/16 1/4 inch drive socket with a long extension, loosen the hose clamp holding the filler tube on the back of the tank and pull the hose off the tank.
    8. Place the floor jack with a piece of wood on it under the gas tank to diffuse the weight. Jack it up just enough to start putting pressure on the tank. Use the 15mm swivel socket, extension, and socket wrench to go through the rear subframe and remove the two 15mm bolts holding the tank straps up. Once removed, pull the straps down and let them drop. They'll pivot on the front joints.
    9. Pull your exhaust hangers off up to the donuts holding the downpipe on and let the exhaust sag, you'll need to do this for clearance to get the tank out.
    10. Slowly drop the tank down until you can reach up and disconnect the vent line from the tank to the charcoal canister, being careful to let the filler port on the back of the tank not hang up on the rear subframe. Slide the tank out and remove any other old quick connect lines under the car.
    11. Feel free to do any cleaning, rustproofing, undercoating at this step since you'll have a ton of room to work with. If not, at this stage you'll remove the old tank straps and install the new ones for the plastic tank. This can be done by pivoting them out of the forward slots in the floor.
    12. This is optional if you have the new filler spout. Go ahead and install it with the fill hose from the car you got the new tank from. If not, you'll have to cap off the vent line on your filler spout and cut and extend the fill hose by 2.5 inches with a 1 inch diameter by 4 or 5 inch piece of exhaust tube or galvanized plumbing tube and hose clamps. this is because the fill port on the new tank is 2.5 inches further to the right on the new tank because the charcoal canister is built on the new tank.
    13. Remove the exhaust heat shield from the plastic tank and set aside for now. You'll put it back on once the tank is up. Slide the new tank up in place and jack it up careful that the fill port clears the rear subframe. Route the vent hose from the charcoal canister on the tank towards the previous location of the old canister.
    14. Attach and start the bolts for the tank straps by a few threads, then go up to the access port in the trunk and attach the electrical lines. These are easier to connect with the tank down just a hair for more finger room. Back under and run the bolts up tight for the tank straps and remove the jack. You can reinstall the exhaust heat shield now that the straps are in place.
    15. Attach and clamp down the filler hose to the tank, and attach the fuel lines at the filter and return. There's a slight change in the evap line connection. On the new connection it's the same style as the fuel line quick connect with the little plastic retainer instead of it being a squeeze and release. You'll see what I mean when you're down there. . You'll need to take the quick disconnect plastic retainer off the return line connection on your old fuel pump and use it to connect the evap line to your steel line by the fuel filter.
    16. Attach the new 5/8ths vent hose to your old one with the bared fitting and run it back into the wheel well where your old charcoal canister was and attach the vent solenoid to the bracket in there from the old canister. Plug in the electrical connector to the solenoid.
    17. Reinstall the inner fender liner and reinstall your left rear wheel and lower the car on to the ground.
    18. This is an important step as the newer style fuel pumps aren't a dual speed pump, you need to remove your passenger headlight and locate the connector for your fuel pump resistor. Cut the wires on the resistor side of the connector and splice them together with an all weather crimp connector. This will ensure that the pump gets full voltage.
    19. Put gas in the tank from what you removed from the old tank and cycle the key a few times to build pressure. Fire it up and check for leaks and you're done!
    One thing I noticed right off the bat is the newer fuel pump is WAY quieter than the one in the steel tank. This is also a great upgrade to consider if your tank is rusty and looking like it won't last another salty winter. When I removed the old tank I was amazed at how rusty it was and how it hadn't leaked yet. The bottom of the tank looked great, but the top and sides were rusty as hell. Hope this helps anyone considering a tank swap. As far as I know I'm the first to do it since there are no other threads on it on the several forums I belong to.
  2. #2 Re: DIY: Plastic gas tank upgrade
    mke
    Great write up. What cars did the plastic tanks all come in?
  3. #3 Re: DIY: Plastic gas tank upgrade
    USA
    Quote Originally Posted by jaybaum96 View Post
    02+ grand prixs
  4. #4 Re: DIY: Plastic gas tank upgrade
    Portland Oregon
    Quote Originally Posted by limegreen View Post
    02+ grand prixs
    Also 00+ Impala's and Regals
  5. #5 Re: DIY: Plastic gas tank upgrade
    Love the write up. Only thing though....my 00 has the plastic tank and two speed pump.
  6. #6 Re: DIY: Plastic gas tank upgrade
    Portland Oregon
    Good info Bill. I just know they did away with the resistor in later years so I just wanted to cover my bases if someone did the swap and didn't jump the resistor and has fuel pressure issues or something.
  7. #7 Re: DIY: Plastic gas tank upgrade
    I figured that. But having to bypass my resistor this past summer, it was still fresh. =)
  8. #8 Re: DIY: Plastic gas tank upgrade
    Feb 2010
    TN
    Any way to put a larger tank in these cars?
  9. #9 Re: DIY: Plastic gas tank upgrade
    Jan 2012
    Philadelphia
    Quote Originally Posted by Logan541 View Post
    its an 18 gallon tank how much larger do you want it lol
    and great write up i may be doing this to my 97 in the near future
  10. #10 Re: DIY: Plastic gas tank upgrade
    Nov 2011
    NY
    Why on earth would you want to do that?
    I'd rather put a ten gallon tank in and save the weight... lolz
    (6.3lbs per gallon US, depending on temperature)
  11. #11 Re: DIY: Plastic gas tank upgrade
    Feb 2010
    TN
    will these tanks fit a 97 GT two door? Any any real weight savings?
  12. #12 Re: DIY: Plastic gas tank upgrade
    Portland Oregon
    I doubt you can fit a larger tank Logan. The tanks are basically molded to fit in the space under the car. And yes it should work for any 97-03 car. 04+ may be different but I'm not 100% on that.
  13. #13 Re: DIY: Plastic gas tank upgrade
    Feb 2010
    TN
    Quote Originally Posted by OH4CompG View Post
    Thanks
  14. #14 Re: DIY: Plastic gas tank upgrade
    Come to think about it. Right after getting my car and putting on "a mod or two" in the first couple weeks, I aimed to get a pump. Was told I had to check the label on it because there are two possible pumps in 2000. Maybe that's the swap over year on the resistor.
  15. #15 Re: DIY: Plastic gas tank upgrade
    GTP Level Member
    springfield IL
    ^^^^^^^. Morad auto parts guy told me that also...
    GT Level Member Erics00LS's Avatar
    Lindenhurst, IL
    Uh.. always thought mine was 15. Turns out its 17 by owners manual and everything online. Are you picking up an extra gallon in the filler tube?
    Sent from my SPH-D700 using Tapatalk 2
    '03 Buick Park Avenue Ultra - a few bolt ons
    http://www.facebook.com/groups/greatlakesareacarenthusiasts
  17. #17 Re: DIY: Plastic gas tank upgrade
    Jan 2012
    Philadelphia
    wow long ride but good for you driving all the way up there to see them and good bless them
  18. #18 Re: DIY: Plastic gas tank upgrade
    Feb 2010
    TN
    Quote Originally Posted by gtpeddie View Post
    Thanks mom just turned 95 may 6th
  19. #19 Re: DIY: Plastic gas tank upgrade
    Jul 2012
    Windsor, Ontario, Canada
    Hey guys just got my plastic tank installed all is well and the car runs, but with half a tank of fuel it is registering at full on my fuel gauge, I installed a new fuel level sensor, has anyone else run into this, my car is a 99 GTX and I installed a fuel sending unit from a 03 GTP , I replaced the level sensor before installing it. I don't know if I need to swap some wires or install a resistor in a wire. Any help would be great! Thanks
  20. #20 Re: DIY: Plastic gas tank upgrade
    Portland Oregon
    Shouldn't matter on the sending unit. I would pull it out and turn the key to on and have someone there move the float up and down and watch the gauge on the dash.
  1. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  2. Gas Tank?
    By BlackSun in forum General Tech Discussion
    Last Post: 11-18-2010, 01:45 PM
  3. what was first year for plastic gas tank?
    By Purple Plazma in forum General Tech Discussion
    Last Post: 11-19-2009, 11:48 PM
  4. gas tank?
    By 98gpgt98 in forum Off Topic Discussion
    Last Post: 05-11-2009, 06:19 PM
  5. Metal Gas Tank Flap Broken off and Into Tank
    By indplsin72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2008, 08:35 PM
