Thread: 3-button to 5-button DIC (04+)
Page 3 of 3 FirstFirst 123
Results 41 to 51 of 51
  1. #1 Re: 3-button to 5-button DIC (04+)
    Oklahoma
    Well first and foremost, I want an alternator male and female connector, but not just necessarily for my car but for another make and model. I was hoping it was just one or two sources for those or like some huge outlet that specialized in automotive connectors.
  2. #2 Re: 3-button to 5-button DIC (04+)
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    to a point, but it depends on what make/model you're wanting.
  3. #3 Re: 3-button to 5-button DIC (04+)
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    Pins came in this week and I took some time tonight to install the 2nd DIC. I'm running it open to make sure that everything works OK with the mileage and such but so far, so good. Only thing I noticed is that sometimes, it doesn't read the temperature correctly. Basically, when the 3 buttion is all that is hooked up, the HUD says some random temperature. Once the 5 button is in, it reads the correct temp. Thats when they are by themselves. Now that I have this y harness created and plug them both in, sometimes it recognizes the temp correctly and sometimes not, othertimes, it will be wrong at first and then correct itself. I'll be looking into this a little bit more but good news so far.
    How to should be ready in a week or so once I can confirm its a good option.
  4. #4 Re: 3-button to 5-button DIC (04+)
    SW Chicago Suburbs
    Quote Originally Posted by TyroElite View Post
    worst case scenario would be to get a second temp sensor and wire that one into the 5 button, and leave the other for the 3 button one.
  5. #5 Re: 3-button to 5-button DIC (04+)
    Williamsport, PA
  6. #6 Re: 3-button to 5-button DIC (04+)
    SE Level Member joetronics's Avatar
    Reno, NV
    TyroElite - Couple questions please - Why the GMCell - or is that if you want to use a cellphone only??? The rest I got pretty straightforward from your writeup - which incidentally, I cannot find that anymore - was it removed?????
    I have a 2008 Grand Prix - V6 - and am wanting to do this upgrade - can you forsee any stumbling blocks?
    Thanks
  7. #7 Re: 3-button to 5-button DIC (04+)
    Reno, NV
    This may not be exactly the subject here, but, i am wanting to know what the term "VCI" means - relating the the vehicles programming - could it be "Virtual Channel Identifier" or maybe "Virtual Channel Identification" or even "Vehicle Cone Index".
    Am wanting to know the ramifications of changing the VIN number of the vehicle "electronically only" so I can install some options that require additional codes than what came with the vehicle.......
    So, am I nuts, or is that doable???????
    Thanks for anyone's comments or siggestions......
  8. #8 Re: 3-button to 5-button DIC (04+)
    MO
    only a dealer can program the BCM, that was the problem i had when the BCM went bad in my blazer.
    <brandonl2000> LMAO D!!
  9. #9 Re: 3-button to 5-button DIC (04+)
    Apr 2009
    Athens
    FYI - for anyone wanting to try this upgrade, I just listed a 5-button DIC on ebay. Item 270586810357. It has worked well, but I'm planning to sell the car and I'm putting the original DIC back in the dash.
  10. #10 Re: 3-button to 5-button DIC (04+)
    Canada
    I was told by GM that only a "virgin" odometer can be programmed by a Tech II programmer to a set mileage. Once an odometer sees it's first BCM signals to start recording mileage, it locks out the setting mode and can no longer be reset by a Tech II. Makes sense if you think about it - an dealership could roll back mileage on every used car on the lot.
    There are a couple of specialty reprogramming shops that you can google. There are a couple certified by GM (probably some government regulation too) to be able to set a specific mileage in a non - virgin odometer. They are pricey though - over $200 bucks for the programming plus shipping. I decided to use the second DIC behind the 5 button, and swap as needed.
  11. #11 Re: 3-button to 5-button DIC (04+)
    SE Level Member hklvette's Avatar
    Jun 2010
    Christiansburg, VA
    Quote Originally Posted by surferstick View Post
    Not according to this from GPNOA:
    I finally got sick and tired of dealerships telling my the DIC can not be reprogrammed. Well I finally said screw it and went to the company that developed the software for the tech 2. It took 5 minutes for them to give me the steps. Once I handed this to the dealer I had no further issues.
    Follow the procedure below to program the IPC/DIC:
    Important:
    If the vehicle has air conditioning, you now must turn on the air conditioning feature. - Not really needed due to the update.
    IMPORTANT NOTE: You must keep the old IPC/DIC in the vehicle until prompted to replace it.
    1. Select J2534 Tech 2(R).
    2. Load the VIN number in TIS2WEB.
    3. Highlight (SF) Special Functions and click Next.
    4. Click the Next button and begin the programming process.
    Programming time - 1 to 4 hours
    Using the Tech 2(R)/CANDi module (only), navigate to the IPC module setup function. Perform the function as requested.
    Grand Prixs Of North America &bull; View topic - Reprogramming DIC for Odometer reading
    '05 silver GTP, '98 Cherokee, '78 M880, '70 M35A2
    "Drag racing is for fast cars. Autocross is for fast drivers."
