I think i'm going to try it. How would you do your splice in this case? Cut and solder wires together into branches or some sort of clip on splice?
do you have access to the wiring diagrams/connector views for your car?
if you can get the connector part numbers, we can look and see if you can get the mating connector so you can make a Y harness that is plug and play, no splicing.
