Would this male pin work instead? 12160551 Its gold plated and 100W but seems like it might work better with 2 wires/pin. Your thoughts?
I looked at this one too, and thought it would work, until i looked at it's drawing.
it's meant for a different connector body... wont work...
what you may end up doing is using the smaller pins, and just put one wire in there, and come out, and use solder/heat shrink to make your joint outside of the connector.....
