to a point, but it depends on what make/model you're wanting.
Pins came in this week and I took some time tonight to install the 2nd DIC. I'm running it open to make sure that everything works OK with the mileage and such but so far, so good. Only thing I noticed is that sometimes, it doesn't read the temperature correctly. Basically, when the 3 buttion is all that is hooked up, the HUD says some random temperature. Once the 5 button is in, it reads the correct temp. Thats when they are by themselves. Now that I have this y harness created and plug them both in, sometimes it recognizes the temp correctly and sometimes not, othertimes, it will be wrong at first and then correct itself. I'll be looking into this a little bit more but good news so far.
How to should be ready in a week or so once I can confirm its a good option.
How to is up.
http://www.grandprixforums.net/f73/h...e-no-2107.html
TyroElite - Couple questions please - Why the GMCell - or is that if you want to use a cellphone only??? The rest I got pretty straightforward from your writeup - which incidentally, I cannot find that anymore - was it removed?????
I have a 2008 Grand Prix - V6 - and am wanting to do this upgrade - can you forsee any stumbling blocks?
Thanks
This may not be exactly the subject here, but, i am wanting to know what the term "VCI" means - relating the the vehicles programming - could it be "Virtual Channel Identifier" or maybe "Virtual Channel Identification" or even "Vehicle Cone Index".
Am wanting to know the ramifications of changing the VIN number of the vehicle "electronically only" so I can install some options that require additional codes than what came with the vehicle.......
So, am I nuts, or is that doable???????
Thanks for anyone's comments or siggestions......
First, sorry if this has already been asked, but I searched and found nothing.
I did this 3-button to 5-button DIC mod on a 04 GP that had ~ 80k miles on it. The 5-button DIC had under 10 miles on it when I installed it.
Still have the 3-button DIC hidden away racking up miles. As far as I know it matches the BCM. The 5-button has over 12k miles now.
Question - how can I get the 5-button DIC odometer updated (reprogrammed) to match the BCM as well?
Right now I always take the 5-button out and put the 3-button back in when I take it in for oil changes. I don't want the service records to show the lower mileage because some database somewhere might show this as a rollback of the odometer.
I'd like to get the 5-button mileage to match the car's actual mileage so I can stop doing the swaps.
I talked with the service manager at my local GM dealership. Said he would research it and get back to me. That was over 3 moths ago...
only a dealer can program the BCM, that was the problem i had when the BCM went bad in my blazer.
FYI - for anyone wanting to try this upgrade, I just listed a 5-button DIC on ebay. Item 270586810357. It has worked well, but I'm planning to sell the car and I'm putting the original DIC back in the dash.
I was told by GM that only a "virgin" odometer can be programmed by a Tech II programmer to a set mileage. Once an odometer sees it's first BCM signals to start recording mileage, it locks out the setting mode and can no longer be reset by a Tech II. Makes sense if you think about it - an dealership could roll back mileage on every used car on the lot.
There are a couple of specialty reprogramming shops that you can google. There are a couple certified by GM (probably some government regulation too) to be able to set a specific mileage in a non - virgin odometer. They are pricey though - over $200 bucks for the programming plus shipping. I decided to use the second DIC behind the 5 button, and swap as needed.
Not according to this from GPNOA:
I finally got sick and tired of dealerships telling my the DIC can not be reprogrammed. Well I finally said screw it and went to the company that developed the software for the tech 2. It took 5 minutes for them to give me the steps. Once I handed this to the dealer I had no further issues.
Follow the procedure below to program the IPC/DIC:
Important:
If the vehicle has air conditioning, you now must turn on the air conditioning feature. - Not really needed due to the update.
IMPORTANT NOTE: You must keep the old IPC/DIC in the vehicle until prompted to replace it.
1. Select J2534 Tech 2(R).
2. Load the VIN number in TIS2WEB.
3. Highlight (SF) Special Functions and click Next.
4. Click the Next button and begin the programming process.
Programming time - 1 to 4 hours
Using the Tech 2(R)/CANDi module (only), navigate to the IPC module setup function. Perform the function as requested.
Grand Prixs Of North America • View topic - Reprogramming DIC for Odometer reading
