Quote Originally Posted by TyroElite View Post
Finally my GMCELL showed up. there are 3 wires that do not go between the female and male end (they are the ones ment to go to a phone +/- and mute system) Since the DIC board has all 12 pins, I assume I need to attach these to the male end also right? Can you check this in your wiring diagram? (or post the diagram you have and I can check it)
I'll look when i get to my home pc, but yeah, i think you should ahead and connect them... but since you need to re-pin the male end, you should be ok (the male end you have will end up with 2 wires coming from each pin, (if you ordered the ammount of pins that i posted, you should be fine)
