Thread: Passkey III
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: Passkey III
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Jeckel View Post
    Also please make sure your vehicle is not made in Canada (VIN starts with the number 2) self programming isn't possible for Canadian vehicle.
    That is bullsheet! Way to stick it to the Canadians! LOL
    Thankfully I have two working keys.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  2. #22 Re: Passkey III
    SE Level Member Jeckel's Avatar
    Feb 2010
    Nampa, ID
    i may have missed something, but why do you think its the key? it runs for a few seconds then stalls seems like a fuel pressure resistor gone bad.
    There is nothing wrong with my car. I only have one key and am to cheap to buy another one. If I can eliminate the PK3 then it removes it from future issues. I have had the car for 4 or 5 years and have only had one key.
  3. #23 Re: Passkey III
    SWPA
    And we have showed you where you can get a PK3 key for a few dollars.
  4. #24 Re: Passkey III
    ok then. thats good.
    there is the hack where you zip tie your good key in the column, then use any blank key as you see fit. now thats real cheap.
  5. #25 Re: Passkey III
    Feb 2013
    37.295091, -121.930053
    orrrr find one laying around on the ground at the junk yard
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  6. #26 Re: Passkey III
    Cause.. the security light flashes when it's the key.
  7. #27 Re: Passkey III
    Feb 2009
    flintnasty MI
    If you want to send me a bin file i can eliminate theft in it.
  8. #28 Re: Passkey III
    I'd like one
  9. #29 Re: Passkey III
    new drop box material lol
  10. #30 Re: Passkey III
    Apr 2011
    Elk Rapids, Michigan
    Sorry Bill, too used to living around Detroit! You need any theft deterrent system you can get around there. Disabling VATS would be my last resort.....lol. Living in northern Michigan now, it would be a viable option!
    2001 black GTP coupe, Gen V, ZZP S2IC & billet fuel rails, XP cam, LS7 lifters, 105# springs, ZZP MPS w/3.4 pulley, Northstar tb, LQ4 maf, ZZP headers, K & N CAI, Meziere electric wp, Caspers fp retire, F body front brakes, GMPP strut braces​, Don Rome strut brace mounts.
  11. #31 Re: Passkey III
    hangover park IL
    ive always had issues on the later files 00+ setting theft present to false...on earliers ive had no problem...i always figured it for being due to the BCM being part of the pk3 systems in the later cars instead of a cluster/pk box and pcm. i couldnt delete an achieva one time....
    is it possibly just poorly mapped then on later files?
    ~James~ Psychotic Gearhead
  12. #32 Re: Passkey III
    GT Level Member penright's Avatar
    Mar 2013
    United States
    [Old, but I thought I would throw this out for what it's worth]
    You are right sir....
    When I had remote start added to my 02 GP SE back in 02, they cut the metal part of the key off and cram transponder part up inside the plastic part surrounding the key part. I guess it just has to be close. From then on, I just make regular keys without the transponder part. :-)
    And..if the ignition is bad and not reading the key.. then you need to bypass and stop worrying about keys.
    Bam.. take that key guys
    I know Bill, it won't fix a bad ignition not reading the key. :-) Not a key guy, just throwing it out for those who don't have programmers.
    So Jeckel, what did you find in the end?
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  13. #33 Re: Passkey III
    Feb 2010
    Nampa, ID
    Quote Originally Posted by penright View Post
    I finally got my pc back up and running, and am still trying to find the fuel pump or injector runtime that billboost is talking about in dhp. I remember seeing it, but cannot find it now.
  1. Passkey relearn 2006 gt
    By hulsizer70 in forum Introductions/Noob Questions
    Last Post: 10-25-2016, 07:19 AM
  2. passkey problem
    By GTP Ryan in forum General Tech Discussion
    Last Post: 07-21-2013, 10:06 AM
  3. passkey 3 issue
    By john cola in forum General Grand Prix Discussion
    Last Post: 07-06-2013, 01:23 AM
  4. HELP! Ignition Switch: Removing Passkey Module
    By Lawngoose in forum General Tech Discussion
    Last Post: 06-20-2009, 05:44 PM
  5. Q: PassKey III Relearn - Spare PCM
    By TommyGloves in forum PCM Tuning
    Last Post: 05-13-2008, 08:32 PM
